#1 | |
cps relocation wiring help
I bought an advance adapters cps relocation kit. I swapped in a 4 speed tranny and ford xfer case now i can't get the jeep started. I have fuel but no spark. The only thing that was changed that would kill spark is the cps. How can i test the cps, what should i be looking at for ohms, and if anyone has any pointers to make sure i wired the kit in right would be great. the colors from the directions were wrong so i tested the harness plug end for power and ground and went from there, still not 100% on the thing though. What else could cause no spark. The coil tested fine with the ohm meter. What other wires should i be probing?
"my jeep is pretty much my wife. it gets most of my time, and it loves when i spend money on it." |
#2 |
i'm just curious and can't find it in haynes or chiltons. But which wires going to the cps do what? posts a-b-c. can't figure it out. i found this post
http://www.jeepforum.com/forum/f11/98-4-0-cranks-but-no-spark-coil-627659/ which has some good info in it and tests to run on the cps. I need to make sure i wired it right. advances's instructions are a little bizarre.
| Thread Tools | |
Previous Thread
Next Thread
| Suggested Threads |
