cps - JeepForum.com
post #1 of 21 Old 03-10-2010, 09:26 AM Thread Starter
w212warren
cps
where is the crank sensor on my 89 yj any onehave a pic, jeep died has new coil, icm, wires, dist, it has little spark at coil when i tested it but no spark at end of plug wires, think its the cps mabey
w212warren is offline
post #2 of 21 Old 03-10-2010, 10:06 AM
Que89YJ
The crank sensor is at the top of the bell housing in the rear of the motor.
Que89YJ is online now
post #3 of 21 Old 03-10-2010, 10:13 AM
sentinal02
H2 Recovery Team Member
sentinal02's Avatar
actually I don't think the 4.2L has one.
warren, check your fusible links coming off the starter relay, you may have a burnt one cutting power to the coil.
RIP: '88 YJ 2.5L Ax-5 NP231
Posi-Loked. Herculined. Optima yellow top. 1" Shackle, 2" BDS. Cragar 397's Aussie front.
92 YJ 4.0L Ax-15 231
5" springs, 1" shackle 31's or 35's depending on my mood
sentinal02 is offline
post #4 of 21 Old 03-10-2010, 10:41 AM
Que89YJ
LOL I missed that one! Nope on the 4.2L You are old school! Time to do some mods I think. Time for the nutter bypass upgrade if ignition module is bad. Do they require emission check and vehicle inspections in Winnipeg?
post #5 of 21 Old 03-10-2010, 02:07 PM Thread Starter
w212warren
no emissions check in winnipeg. found the problem my distrubtor was bad. got lots of spark now it wants to fire up but now i have no fuel going to the carb. what next with this thing!!! it has a brand new fuel filter, also its a mechanical fuel pump on the engine so i dont think i can hear a pump turning on. is there a way to check the fuel pump
post #6 of 21 Old 03-10-2010, 02:13 PM
monkeyhouse
have you checked the fuel pressure? I think those mechanical pumps like to put out like 7 lbs of pressure. The webers like 3.0 to 3.5 lbs
Holley makes a good fpr for around 30 bucks, if you get it, you'll need to pick up a gauge and fittings.
First Jeep was an 1989 YJ, 6 cylinder 4.2L , 258. Nuttered and TeamRushed, Weber 38 DGES, Now, I'm venturing into the world of Grand Cherokees
monkeyhouse is offline
post #7 of 21 Old 03-10-2010, 03:28 PM Thread Starter
w212warren
when i pulled the fuel line to the carb and turned the motor over there was little fuel coming out, i will test to see if i got power to the fuel tank then check fuel pressure. i dont think i have a fpr.
post #8 of 21 Old 03-10-2010, 03:37 PM
monkeyhouse
sorry, I don't know why I assumed you have a webber. Are you running the stock carter ?
post #9 of 21 Old 03-10-2010, 04:55 PM Thread Starter
w212warren
running stock carb. i checked the two relays on passenger side fender i get power on 87 pin or 30 pin one or the other. ok this is where i get lot, i got a mechanical fuel pump on block so the wires running to my fuel tank are for my fuel gauge black wire and a beige wire, also have a orange but it is cut of the connector for some reason. so there is no power on a mechanical pump right! how do i find out if my pump is bad
post #10 of 21 Old 03-10-2010, 05:13 PM
ZeroGravity
I believe the crankshaft position sensor is actually abbreviated CKS.
91 YJ
98 XJ
2 door love
The U.S. Army vaguely envisioned something bigger than a motorcycle, smaller than a truck, and undaunted by the most difficult terrain.
ZeroGravity is offline
post #11 of 21 Old 03-10-2010, 06:45 PM Thread Starter
w212warren
ordered a new mechanical fuel pump so i will know tomorrow if it will run. dam jeep is a money pit pretty much everything is new, its one thing after another. i have a xj project i want to start so i want this thing to run so project 4.6l stroker can begin
post #12 of 21 Old 03-10-2010, 06:51 PM
Burnerman
Burnerman's Avatar
Am I missing something?? A mechanical fuel pump has no wires to it. You need to get a Haynes or Chilton manual. The wires going to your fuel tank are for the fuel gauge. You are using troubleshooting step for a fuel injected system but you have a carbed engine if its a 4.2L and hasn't been converted to FI. Please explain your current engine setup.
96 ZJ.
05' Grand Cherokee Limited, 2"OME lift
Burnerman is offline
post #13 of 21 Old 03-10-2010, 07:05 PM Thread Starter
w212warren
burner that is what i was say the wires must be for fuel gauge. its a carb and a mechanical fuel pump. just not getting fuel to the carb so i ordered a new pump hope thats the fix
post #14 of 21 Old 03-10-2010, 08:03 PM
monkeyhouse
always a good idea, not that expensive and have a tendacy to go bad.
post #15 of 21 Old 03-10-2010, 08:07 PM
green89yj
You can check the pump by disconnecting a line after the pump and holding it into a bottle while you crank. It should put out a pretty large amount of fuel.
Herc.Custom Green paint. RC 4". 5 Goodyear 33X12.5 MT/R w/Kev. Cragar V5's. Corbeau Moab seats. Optima Yellow.XRC8 Comp Winch. XJ 4.0/AX15
WTT: 4" springs for 6"
WTS: 4.2 parts. Fuel lines, pump, block, head, accessories, just ask
green89yj is offline
