Cowl Dent Removal - JeepForum.com
post #1 of 7 Old 07-10-2009, 02:47 PM Thread Starter
CajunHiker
Cowl Dent Removal
Eugene Jr. took a tree limb back during Katrina. What's the best way to remove this dent? I wouldn't mind putting a cowl snorkel there if I could figure out how to route it.
CajunHiker is offline
post #2 of 7 Old 07-10-2009, 03:12 PM
sam.b.
Take dash all out and possibly steering column and use body tools to beat it back out as best you can and bondo it.
OR cut it out and weld in a new piece bent to shape.
98 TJ Mild DD
90 YJ Sold
88 Samurai slowly being built for the rocks
<< Louisville Ky. based 4x4 club
sam.b. is offline
post #3 of 7 Old 07-10-2009, 03:15 PM
57plymouth
Stud gun or slide hammer from the top is the lazy way. Can you reach it from the cowl vent?
Virtus Junxit Mors Non Separabit
57plymouth is offline
post #4 of 7 Old 07-10-2009, 03:27 PM
ziebartrob
Have you had a paintless dent guy look at it? Dent Wizard took a nasty fist shaped dent out of the tank on my bike.
ziebartrob is offline
post #5 of 7 Old 07-10-2009, 06:01 PM
93jeepyj
Ha, I literally just painted my jeep today. A dent in that exact location is what started all my body work. a buttload of ice fell of a slate roof and trashed the front of my jeep two years ago. I knocked some of it out with a piece of scrap wood with a rag over the end of it but it still ended up needing body filler becasue it was creased. If there isnt a crease on yours theres a better chance of you or a dent guy getting it out without paintwork.
93jeepyj is offline
post #6 of 7 Old 07-10-2009, 06:15 PM Thread Starter
CajunHiker
What about one of those suction cup pullers?
post #7 of 7 Old 07-10-2009, 08:16 PM
chuddly
nope a suction cup puller wont work...first off the metal is to thick and to much curve and its creased. ice wont do it either.
your choices are
1. cut that part out and beat it out then weld it back and do body work
2. SEE if you can get it by removing the dash.
3. pull pins in a stud gun. This is the fastest but will require more body filler.
by the way i have been doing paint and body work for a living for 15 years and i own my own shop
chuddly is offline
Dent Doctor plk457 JK Wrangler Technical Forum 17 04-08-2010 07:38 AM
Little Dent... TJoshX TJ Wrangler Technical Forum 12 02-15-2009 10:17 AM
oil pan dent rubiwannabe TJ Wrangler Technical Forum 8 06-01-2008 06:46 AM
Dent Removal rchs.band JK Wrangler Technical Forum 2 05-26-2007 03:06 PM
Oil pan dent? jclaudii TJ Wrangler Technical Forum 9 09-12-2006 11:07 AM
