Covering Air Vent - JeepForum.com
post #1 of 6 Old 09-26-2005, 06:52 PM Thread Starter
mance
Covering Air Vent
Does anyone know if it would be a bad idea to cover the air vent near the front wind shield completely?
1992 Jeep YJ
4L, 6Cyl Manual Transmission
4" Lift 2" Body
33 MTR
mance is offline
post #2 of 6 Old 09-26-2005, 06:53 PM
parpac316
parpac316's Avatar
why would you want to do that?
parpac316 is offline
post #3 of 6 Old 09-26-2005, 07:05 PM Thread Starter
mance
Quick fix to stop water from coming in to the floor boards. I also read somewhere in another post that someone also did this and it stopped the leak. I just wanted to know if there are any problems if I were to do this. Thanks
1992 Jeep YJ
4" Lift 2" Body
33 MTR
mance is offline
post #4 of 6 Old 09-26-2005, 07:19 PM
bono426
bono426's Avatar
if you have a leak in the floors, try this. open up the hood and look for a hose about an inch-1.5 wide and see if its clogged up. the hose will be running from the bottom of the vent against the fire wall. take it off and remove the crud that could possibly be in there. if that doesnt work then you might have a clog under your vent near that little hole
this worked for me, so its worth a shot,
charlie
1998 ZJ (What in the heck is a ZJ?)
5.2 V8
bono426 is offline
post #5 of 6 Old 09-26-2005, 07:30 PM Thread Starter
mance
Hey Thanks, I'll try that first.
1992 Jeep YJ
4" Lift 2" Body
33 MTR
mance is offline
post #6 of 6 Old 09-27-2005, 03:28 PM Thread Starter
mance
Hey thanks for the tip. Sure enough I found that hose and it was clogged with mud and leaves. Cleaned the cowl and the hose seems to be draining properly. Again thanks for the help.
1992 Jeep YJ
4" Lift 2" Body
33 MTR
mance is offline
AC/Heat vs. Vent (( vent dosen't work idk why )) gamer0 YJ Wrangler Technical Forum 10 04-10-2009 10:24 AM
Soundbar Covering twhditto TJ Wrangler Technical Forum 5 08-01-2007 08:52 PM
Floor Covering OBK TJ Wrangler Technical Forum 2 04-24-2007 11:50 AM
Covering up those Dings Optik45 TJ Wrangler Technical Forum 2 08-20-2004 07:02 AM
floor covering Dembones YJ Wrangler Technical Forum 19 01-08-2003 07:24 PM
