Courtesy lights out??? - JeepForum.com
post #1 of 4 Old 11-13-2001, 09:25 PM Thread Starter
12345Michael
'94 YJ Hard Top
Interior courtesy lights are dead.
One was working. I replaced bulb in other and, I think, shorted out the socket temporarily. No short now.
Checked all fuses: good.
All fuses have voltage on both sides.
No voltage on pin switch at driver's door.
Also, heater blower is dead.
Wirering diagram in Manual is useless!!!
Any ideas?
Thanks
Michael
12345Michael is offline
post #2 of 4 Old 11-14-2001, 11:02 AM
4-low
Hi!,
check your wiring diagram for where the wires run and such, and check the harnessess, last winter I lost my brake lights......not the spare tire one though...and i had no idea what the hell to do,,...after any hours in the bloody cold, I discovered that in one harness under the dash above the brake pedal, a wire had popped out....put it back in the harness, and hot glued the bastard in <not the best fix, but it's worked>......i've also found with other problems with electrical in other cars to check the harnessess for loose wires...
hope this helps.
MMMMMMIKE
4-low is offline
post #3 of 4 Old 11-14-2001, 08:41 PM
FLHT_FXRS_YJ
FLHT_FXRS_YJ's Avatar
What's a courtesy light? Mine hasn't worked in the 10 years I've had my yj. Just keep a flashlight or two handy!
89' YJ - 4.2 - NV4500 - NP231w/sye - 1" Body Lift - 2 1/2" Rancho Suspension Lift - 31" Firestone MTR - AR Outlaw II - Tomken Bumpers F & R - Warn 8000 front - Warn 6000 rec. mount rear - FlowFit Seats - Tom Woods Rear & Custom 2" front driveshafts
FLHT_FXRS_YJ is offline
post #4 of 4 Old 11-15-2001, 07:53 PM
my litte red yj
yea my dome lite wont work i checked fuses all were good the wire to the lite under the dash is dead no power????
my litte red yj is offline
Courtesy lights johnson1178 YJ Wrangler Technical Forum 8 05-11-2010 07:18 PM
Doors Off '97 TJ - Courtesy Lights On Shoalwater TJ Wrangler Technical Forum 28 07-01-2009 01:45 PM
trying to get soundbar lights on with courtesy johndeerebones TJ Wrangler Technical Forum 1 04-11-2009 10:24 PM
Help with interior courtesy lights lilngineer TJ Wrangler Technical Forum 2 10-12-2007 06:14 AM
Courtesy Lights? JeepViper TJ Wrangler Technical Forum 2 11-09-2004 01:13 AM
