couple Oil questions... - JeepForum.com
post #1 of 7 Old 04-16-2010, 08:42 PM Thread Starter
SkullTripper
1987 YJ Wrangler
I put some oil in my Jeep it was runnin a little low when I opened iy up and poored the oil in I went to put it back on and it doesn't seem like its tight... I pressed down still nothing and it turns in infanite circles without locking... second question is If i mixed 10w 30 with 10w 40 would there be any probs?
Its a Jeep thing....
My 1987 Jeep Wrangler Build..
SkullTripper is offline
post #2 of 7 Old 04-16-2010, 08:47 PM
Burnerman
Burnerman's Avatar
Mixing oil won't hurt anything. I have no idea what your other question is. You oil fill cap is broken?
96 ZJ.
05' Grand Cherokee Limited, 2"OME lift
Burnerman is offline
post #3 of 7 Old 04-16-2010, 09:10 PM Thread Starter
SkullTripper
1987 YJ Wrangler
yeah the oil fill cap won't tighten down it just keeps spinning
post #4 of 7 Old 04-16-2010, 09:16 PM
bharris68
Did the lcking tabs break off of it? Flip it over and take a picture of it.
bharris68 is offline
post #5 of 7 Old 04-16-2010, 09:30 PM
TDHofstetter
Long ago (well within my lifetime), it was a very very very bad idea to mix oils of two different BRANDS together - like it's filled with Havoline, ya top it up with Quaker State, bad stuff happens. Today's oils are very different from yesterday's oils, but still I get tense about mixing two different brands. No problem with a different viscosity oil, but I don't like to mix brands.
At an oil change, I may switch brands... na, I don't even do that - I've been using Pennzoil since the late 1970s. It may be time for me to look around, though, & maybe switch to Rotalla for the CJs.
TDHofstetter is offline
post #6 of 7 Old 04-17-2010, 02:34 AM Thread Starter
SkullTripper
1987 YJ Wrangler
maybe I should just change the oil...How many jugs does it take of the $5.00 to fill it up.. plus would synthetic and regular mixing be bad? I will get pics up of it Sunday because I'm going on a ride today(17th) with Planedog w/ GA trail riders and I'll be gone at beasly knob pretty much all day but I will for sure get a pic up sun thanks you guys
post #7 of 7 Old 04-17-2010, 09:20 AM
stickfight
Mixing conventional and synthetic oils isn't bad, you can even buy it preblended in the bottle.
6 jugs (quarts).
stickfight is offline
Couple more questions QTEX TJ Wrangler Technical Forum 1 05-29-2007 04:41 PM
Couple of Questions deekayindajeep TJ Wrangler Technical Forum 2 07-05-2006 07:41 PM
Couple TJ/LJ questions omega1300 TJ Wrangler Technical Forum 18 07-01-2006 12:49 AM
Couple YJ questions BreakJeepParts YJ Wrangler Technical Forum 8 03-18-2006 08:29 PM
Couple of questions blackw YJ Wrangler Technical Forum 1 04-14-2004 12:48 AM
