Could use some help identifying some loose wires - JeepForum.com
post #1 of 8 Old 08-08-2013, 08:49 PM Thread Starter
CJ5_Fan
CJ5_Fan's Avatar
1980 CJ5
Hi folks,
Normally I am a CJ guy and can deal with wiring issues due to the lack of electrical accessories on my CJ keeping things simple but I picked up a 1989 wrangler recently and it has a couple wires I can't quite figure out where to reconnect.
I would appreciate it if somebody can identify these 3 for me so I can hook them back up.
Here is the first:
Here is the second:
And here is the third:
BTW- this is a 4.2L i6 with an automatic transmission (32RH)
Thanks in advance for your help!
1980 CJ5 Renegade with 304 v8
CJ5_Fan is offline
post #2 of 8 Old 08-08-2013, 09:37 PM
rocketboy
rocketboy's Avatar
Interesting. I went out and looked at my 89 and it has all three of those connectors and they aren't connected so anything.
The middle one I'd noticed before. I always assumed it maybe had something to do with the washer fluid. The other two I had never seen before and dug around and found them stuffed behind the wire harnesses.
BTW, your 89 looks one heck of a lot cleaner under the hood than my 89! My other (much newer) cars don't look that clean.
___________________
1989 YJ - 4.0L
2001 WJ 4.0L
rocketboy is online now
post #3 of 8 Old 08-08-2013, 09:42 PM
UnFocused
The first is the hot lead to the hood light, if equipped. A mercury switch mounted light under the hood near the passenger side hinge. Turns on when the hood is raised.
The second is the ground for the rear window washer fluid pump if equipped. There would be two separate pumps on the bottom of the washer fluid reservoir.
The third is obsolete. Originally the YJ had a computer controlled electrical valve which closed off the PCV circuit at idle, not allowing the PCV to vent gasses to the carb. That was eliminated by a factory recall later on. Thatís the original plug. You should have an unobstructed run from the PCV to the base of the carb.
UnFocused is offline
post #4 of 8 Old 08-08-2013, 10:06 PM
bpounds
bpounds's Avatar
Thanks so much for that info. I've got all three of those loose wires too, and wondered what they were. Now I know.
I wouldn't mind putting the hood light on.
bpounds is offline
post #5 of 8 Old 08-08-2013, 10:06 PM
rocketboy
rocketboy's Avatar
Interesting. Makes sense since my Jeep has no hood light or rear window washer.
___________________
1989 YJ - 4.0L
2001 WJ 4.0L
post #6 of 8 Old 08-08-2013, 11:29 PM
Tyler980
I have them all unhooked as well haha. But the one to the hood light is too badly melted to reconnect and super clean under that hood :thumbsup
Tyler980 is offline
post #7 of 8 Old 08-09-2013, 01:04 AM Thread Starter
CJ5_Fan
CJ5_Fan's Avatar
1980 CJ5
Thanks for the info!!!!
CJ5_Fan is offline
post #8 of 8 Old 08-09-2013, 01:12 AM Thread Starter
CJ5_Fan
CJ5_Fan's Avatar
1980 CJ5
Thanks, just bought it 2 weeks ago and it is in really good shape. Paid $4500 for it.
But the motor of my CJ is cleaner
CJ5_Fan is offline
