Could use some help - JeepForum.com
post #1 of 7 Old 10-17-2013, 07:46 PM Thread Starter
dokrob
Could use some help
Ok so I got under the jeep (1993 2.5 wrangler) to check on a leak and looked up to see my flywheel. I'm no mechanic but shouldn't there be a cover of some sort on this? Could I really have been driving all this time and missed this? Any help is greatly appreciated. Thanks.
The pain was inflicted and I was addicted..
dokrob is offline
post #2 of 7 Old 10-17-2013, 07:50 PM
95YJRusso
There's a thin sheet of metal that is supposed to go up there, some people call it an inspection shield because you can just up bolt it and take a quick look at your flywheel. if you look up about halfway on the sides of the bell housing you should see where it fastens up
Had I known Jeeps were going to be this addicting, I probably never would have bought one!
95YJRusso is offline
post #3 of 7 Old 10-17-2013, 07:51 PM
95YJRusso
Actually it looks like your missing the bottom bolts which will hold it in
post #4 of 7 Old 10-17-2013, 08:55 PM Thread Starter
dokrob
Thanks for the quick response, should be an item I can get from the dealer? Any special instructions or simply a cover for the flywheel? Probably a good idea to replace it before I drive it too much huh?
dokrob is offline
post #5 of 7 Old 10-17-2013, 11:18 PM
jokerchief462
There is actually a dust cover. To install one you have to remove the starter to get it hung and yes it is held in place by four bolts.
Here is one good price
http://www.ebay.com/itm/Jeep-Wrangle...43b8b2&vxp=mtr
89YJ 2.5L TBI, AX-5, NP231 SYE, Ford 8.8, Yukon Grizzly, Tom Woods Shaft, 33" BFG T/As, 4" lift, Warn VR10000s.
AF Jeep Club Tail #184
jokerchief462 is offline
post #6 of 7 Old 10-17-2013, 11:22 PM
95YJRusso
post #7 of 7 Old 10-19-2013, 10:47 AM Thread Starter
dokrob
Thanks to everyone for their help,I was able to get a used flywheel inspection plate at a Jeep junkyard for $25. Putting it on today and feeling a lot better about it. Time to see what's next... JEEP, Just Empty Every Pocket
dokrob is offline
