Could somebody list the plus's and minus's of locking front axle permanently on YJ - JeepForum.com
post #1 of 10 Old 01-27-2010, 08:26 AM Thread Starter
gary1
gary1's Avatar
I've read different accounts on this forum concerning bypassing the vacuum motor to lock front axle. I am considering eliminating the vacuum activation of front axle and moving the fork on vacuum motor shaft into the locked position and keeping it there. I've read that this is the same setup the TJ Wranglers have. If that is really the case it would seem that this would present no problems at all. Are there any minus's to this setup, and if so I wonder why Jeep ever went to the solid axle on the TJ's.
To acquire knowledge, one must study; but to acquire wisdom, one must observe.
gary1 is offline
post #2 of 10 Old 01-27-2010, 08:36 AM
Joe Dillard
Electric Chair Operator
Joe Dillard's Avatar
YJ = factory didn't balance the front drive shaft
TJ = they did
So, there's the potential that you may get front drive shaft vibrations.
Joe Dillard is offline
post #3 of 10 Old 01-27-2010, 09:06 AM
Flajeeper1
1987 YJ Wrangler
Vaccuum lock
Changing the front axle vaccuum lock to a mechanical is easy and inexpensive. Look for a plastic coated cable to keep the dirt and water out.
Flajeeper1 is offline
post #4 of 10 Old 01-27-2010, 09:14 AM
kloppk
TJ = they did
Plus...
YJ - single u-joint at the tcase
TJ - double u-joint (CV) at the tcase
True about DS vibes due to lack of balancing.
A slight decrease in already dismal MPG's.
Increased wear in the tcase since the front DS will be spinning cuasing the tcase chain, etc to be moving all the time.
kloppk is offline
post #5 of 10 Old 01-27-2010, 09:47 AM Thread Starter
gary1
gary1's Avatar
Originally Posted by kloppk View Post
Plus...
Based on everything that has been pointed out here, would you think it would be wise for me to make this change, or go ahead and put the $'s into making the old system work. I only put about 5000 easy miles per year on this vehicle. My 4 wheeling consists most of winter driving, and pulling a trailer up into the woods for firewood.
My problem right now is that it is taking longer and longer to engage in 4wd when I shift the lever. By the time it engages I don't need it anymore. I suppose it could be as simple as a vacuum leak. I haven't actually gotten under the Jeep and tried to pinpoint the problem. I just thought if it had all the advantages of a TJ and no drawbacks, I would make the change.
gary1 is offline
post #6 of 10 Old 01-27-2010, 10:01 AM
Flajeeper1
1987 YJ Wrangler
First thing is, if you have a vacuum leak you need to find it and fix it. If that fixes your front axle engaging issue then you're in business. If you go to a mechanical cable engage design vacuum is'nt an issue anymore.
post #7 of 10 Old 01-27-2010, 10:04 AM
kloppk
Well it costs nothing to give it a try.
Just a matter of popping the disco unit off the axle, removing the "C" clips on the shift rail, sliding the fork all the way to the drivers side and then re-installing the "C" clips and re-installing the disco unit on the axle.
Be sure to line the shift fork up with the shift collar upon re-installation.
If you DS is balanced good enough for your driving situation then leave it locked.
If the vibes are too great for you then you may wish to fix the existing system.
kloppk is offline
post #8 of 10 Old 01-27-2010, 02:00 PM
540i
I changed my to locked up all the time, put in an XJ front driveshaft and love it. Yank it into 4 Hi and you are there, no waiting. I've put several hundred highway miles on it now and have no complaints.
540i is offline
post #9 of 10 Old 01-27-2010, 02:02 PM
wendell
1987 YJ Wrangler
Go ahead and lock the axle in, it's the most dependable automatic solution. Ford did away with the vacume setup on the 01 rangers and made them a direct connect system. I've had an 04 and an 09 without a problem. I would rather have it that way. Just pull the t-case lever and you know your in 4wd, nothing else to mess with. The willys jeeps were that way. They should of never did away with lockout hubs. I guess they thought us americans were too lazy to get out and lock them in.
1987 wrangler, 258 I-6, 5-speed.
2007 liberty sport 4X4, automatic
2009 ford ranger 4x4 FX4 OFF/ROAD, 5-speed
wendell is offline
post #10 of 10 Old 01-27-2010, 06:13 PM
NHfireLJ
NHfireLJ's Avatar
any special mods to this set up? is there a write up?
Thanks
NHfireLJ is offline
Anyone permanently lock their front axle? roblun YJ Wrangler Technical Forum 11 07-29-2014 09:15 PM
LSD For Front Rubicon Locking Axle my05rubi TJ Wrangler Technical Forum 27 12-22-2008 12:23 PM
locking hub-front axle disconect Goobersbro YJ Wrangler Technical Forum 4 11-13-2008 10:32 PM
Locking front axle and drivability Pointblank TJ Wrangler Technical Forum 8 11-17-2006 07:03 PM
Locking my front axle. A few questions quitelifted TJ Wrangler Technical Forum 5 03-18-2006 08:39 PM
