Could I be in 4 wheel drive all the time? - JeepForum.com
post #1 of 10 Old 04-08-2010, 11:07 AM Thread Starter
mark12010
I have a 90 YJ and I swapped in a 4.0 from a 94 last summer it works great but I have had a few gauge issues to work out, no biggie. My 4X4 indicator light wasn’t hooked up so I hooked it up put the jeep in 4 wheel drive and started it. The light came on. When I disengaged the 4 wheel drive the light stayed on. I pulled the vacuum line off the indicator switch and I have constant vacuum. So I went to the front axle and I have constant vacuum there as well. I went to the transfer case and noticed that I can only move the lever from 2wd to 4 high when I try to move the lever on the transfer case to neutral or 4 low it won’t budge. What the hell is up with this? Am I supposed to have constant vacuum at the indicator and the front axle?
mark12010 is offline
post #2 of 10 Old 04-08-2010, 11:15 AM
wrathobigv
Cant wait for this answer, I have had the same issue, for over a year and it just let go a couple weeks ago. I lost alot of vibration when it let go. So i was wondering the same thing. I changed my vac sensor in my D30, and TC also. I know my TC was in 2wd, but I was wondering if my hubs stayed engaged.
Sorry I couldnt help ya, but thanks for asking this ???
wrathobigv is offline
post #3 of 10 Old 04-08-2010, 11:32 AM
rustywrangler
Got my eye on you.....
rustywrangler's Avatar
First off, You need to do this while driving the jeep, not sitting in place or it wont work.
Second, in order to go to neutral and 4 lo, you need to move the shifter to the right about 3/4" because there is a Z gate to prevent you from dropping it into 4lo at speed.
Third, a basic lesson in shifting the 231 case. You need to be moving at least 5mph in order for it to shift properly in and out of 2HI-4HI. You can do this up to 45 mph (if you need 4wd at 45mph, maybe you need to slow down FYI).
In order to get into 4 LO, you need to be at a crawl just slightly moving and already be in 4HI.
Congenital Heart Disease is a reality for me, BOTH of my children have it. Please read up and become aware for future generations
Lydia Ann-Acquired 08/05/05 Open Heart surgery 08/10/05
Jacob Patrick-Acquired 01/17/08 Open Heart surgery 02/15/08
rustywrangler is offline
post #4 of 10 Old 04-08-2010, 11:41 AM
Fhajad
I've shifted to 4-Hi at 70 mph. (Bridges along the interstate just for "in case" sake of if there was black ice since bridges freeze faster and all that jazz.)
Fhajad is offline
post #5 of 10 Old 04-08-2010, 12:13 PM
Louie4
I'm not sure about the '90 models but my vacuum shifter has two vacuum ports and there is always constant vacuum on one depending on if I'm in 4wd or not. One side pulls the fork over and the other pulls it back. Now I did have the same issue you are having with the indicator light. I pulled the cover and found that my shifter motor had gotten stuck so I cleaned it out good and it works fine now. Well I think it does. My switch for the light was knocked off by a rock a few years ago. Since I have filled it with JB Weld.
Lou
YJOTM July 2012
YJOTM February 2014
Louie4 is offline
post #6 of 10 Old 04-08-2010, 12:21 PM
rustywrangler
The manual says any legal speed but honestly, there really is no need for it at that speed.
post #7 of 10 Old 04-08-2010, 12:21 PM Thread Starter
mark12010
I was not using the lever inside the cab. I dissconnected it and was moving the actual linkage on the transfercase.
post #8 of 10 Old 04-08-2010, 12:23 PM
rustywrangler
It is fairly hard to do it with just the linkage. There is alot of torque in that little lever setup.
post #9 of 10 Old 04-08-2010, 12:33 PM
srf4life
WOW I was not aware that I should be shifting from 2H to 4H while moving. I have always done this while stopped.
I know that I need to adjust the linkage somewhat because I can not get into 4L. This occurred after I added my 3/4 shackles.
The 4WD indicator is out but I know I am spinning the front wheels at least as of last month when I went to the mountains. The indicator was out but the 4WD worked perfectly. I will check the switch and the light. God forbid it finally may have burned out after 21 years hahahaha
1989 YJ, 4.2L, Weber 32/36, Nuttered, 33 inch BFG AT's on 15x10 Eagle Alloys, 2.5 inch Rough Country, 3/4 inch Warrior Shackles, Ground Pounder Fab Rear Bumper with Swing Out Tire Carrier
srf4life is offline
post #10 of 10 Old 04-08-2010, 01:11 PM Thread Starter
mark12010
I realize this but when I hook up the shifter, and yes I am aware of the Z gate I can pull it down to 4 hi but a team of 20 men couldnt pull it into neutral or 4 low. I know it isnt the shifter because when dissconnected from the transfer case the shifter moves freely.
why does my new jeep have part time four wheel drive? OlllllllO Dan TJ Wrangler Technical Forum 20 08-11-2010 08:07 PM
YJ front drive spinning/posi-lock/no 4 wheel drive bdfletch YJ Wrangler Technical Forum 7 11-09-2009 10:58 PM
how do i fix my 4 wheel drive - when in 4wheel drive only one wheel turns c-wag YJ Wrangler Technical Forum 3 06-01-2009 10:45 AM
Four Wheel Drive Light on all the time. Jeeeeeeeeeeeeep YJ Wrangler Technical Forum 14 05-08-2008 02:48 PM
What years have "part-time" 4 wheel drive? coppa TJ Wrangler Technical Forum 25 04-02-2005 12:57 PM
