COST? Bottom End (only) Rebuild - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > YJ Wrangler Technical Forum > COST? Bottom End (only) Rebuild
Rough Country Deals at JeepHut.comIntroducing MONSTALINER™ UV Permanent DIY Roll On Bed LineEngo winches available at www.rockridge4wd.com! Free shipp
Unread 09-07-2009, 09:23 AM   #1
AtzMaBoy
Possible spun a bearing... Growling near bottom of water pump with some associated ticking...
4cyl, 158,000, Manual Trans - Any idea what a bottom end rebuild would run at a shop - no frills/extra's job?
I know this is kind of a open ended question - how many miles; how much wear; was it well taken care of; "your in this deep might as well change xxx too" ...this I understand. The question is: approx $'s to do the bottom end at a shop?
Thanks
1988 YJ, 2.5 4cyl TBI, 5 Speed, 4WD, 31's. Repaired ECU, Herculined. Wrenchin', scrapin', learnin', paintin', enjoy'n! - The "Work in Progress" …continues into '11! (althought she's been on the road since '08! Enjoy it Dad!)
AtzMaBoy is offline   Reply With Quote
Unread 09-07-2009, 10:57 AM   #2
Ironworker709
Ironworker709's Avatar
Most shop "rebuilds" cost alot more than buying a "remanufactured" short block.
Do a search online and see if anyone sells just the shortblock remanufactured,then compare the prices of a rebuild at a local shop,i think you'll be surprized.
Plus most engine remanufacture's have a warranty on them,have yet to see a shop rebuild one with a mileage/time warranty.
Jackson NexGen Welding lens/hood for sale cheap for JF members....
http://www.jeepforum.com/forum/f169/.../#post15415897
Don't DREAM your life, LIVE your dreams
Never forget 9/11
"Welding is like a woman,Get 'er HOT and Penetrate"
Gotta LOVE a person who knows everything about NOTHING
"How far you go in life depends on your being tender with the young,compassionate with the aged,sympathetic with the striving,and tolerant with the weak and strong--because someday YOU will have been all of these"....George Washington Carver
Want to know what an Ironworker is and the job scope of a Journeyman?..click here...http://www.ironworkers.org/becoming/careers.aspx
Ironworker709 is offline   Reply With Quote
Unread 09-07-2009, 11:10 AM   #3
imstillatwork
When the time comes (I have a feeling it will be withing 1 or 2 years - a little knock going on down there now...) I'm going with a reman bottom, I can rebuild a head myself. A lot of labor to swap everything over, but a HUGE saving in money.
imstillatwork is offline   Reply With Quote
Unread 09-07-2009, 11:16 AM   #4
Ironworker709
I did a quick search just out of curiousity since i also have the 2.5.
I couldn't find any short block kits,but alot of long block ,averaging around 1200.00 but thats with warranties too,one being a 7 year/70,000 mile warranty.
If your looking to go cheap as possible,i would think someone here might have a good running used 2.5 laying around after swapping out for a V8 or 4.0.
Might worth asking,might get the whole engine real cheap and worth paying the shipping,then just put all new gaskets and seals in it while you have it out and put it in,in my case i would put a new cam,lifters and timing chain in too.
Never forget 9/11
Unread 09-07-2009, 11:37 AM   #5
AtzMaBoy
$1175.00 seemed to come up / 7yr-70K...
The jeep is (retired dad's). Looking for cost effective fix. Not even positive of the failure yet.
