Correcting Rear End Angle - Page 3 - JeepForum.com
post #31 of 34 Old 05-24-2013, 09:43 PM Thread Starter
DirtyDog
Thanks Siva for the link but a lot of it was too technical and advanced for me. I did read it though.
I had the damaged U Joint changed today like you suggested without shimming, and I didn't feel any vibrations driving around town.
I am going to run it by the offroad shop tomorrow and have one of the guys take a look and let me know what they think.
DirtyDog is offline
post #32 of 34 Old 05-25-2013, 12:46 AM
Siva283
That's s good plan. Double check what the shop with is jere on the forum to be sure though
Sent from my Galaxy S3 using JeepForum
Ask me how I know...
Siva283 is offline
post #33 of 34 Old 05-25-2013, 12:50 AM
Siva283
Also if you have any questions about anything you read on the page from the link feel free to ask and we will try to fill I'm tje blanld to help you understand
Siva283 is offline
post #34 of 34 Old 05-26-2013, 06:05 PM Thread Starter
DirtyDog
Okay, took the YJ by the shop yesterday and the owner put an angle finder to it. He said everything was almost dead on and, he didn't recommend shimming at this point.
The guy who checked it does quite a bit of work on race cars, and he seemed very knowledgable on drive shafts and angles b/c he has to customize drive shafts all the time. He didn't even charge me anything to look at it.
I think he said it was 85 degrees at the transfer case and 83.5 degrees at the rear axle, and he explained how those angles cancel each other out which the article talked about.
I didn't feel any vibrations either driving over there, so hopefully my U joint holds up. So, for now, I will just leave things be and if I have to put a shim under there, I am fairly certain 2 degrees would be the most I want to use. Thanks all for your help.
DirtyDog is offline
