Correct Speedometer - JeepForum.com
post #1 of 11 Old 03-27-2002, 07:02 AM Thread Starter
Rzrseg
Correct Speedometer
Howdy,
Okay, we got this new jeep and the speedometer is reading wrong.
It's a 94 Wrangler. It has 4.61 gears and 32" BFG's. Can someone point me to a link that will tell me the correct adapter I need?
Thanks.
94 YJ, Hard Top, 6 cyl, 4.10's, 4" lift, 32" BFG's, Air Locker front
<a href="http://photos.yahoo.com/rzrseg" target="_blank">http://photos.yahoo.com/rzrseg</a>
Rzrseg is offline
post #2 of 11 Old 03-27-2002, 07:45 AM
Atropine
Atropine's Avatar
I think this will help, its under wheels and tires
<a href="http://www.gotjeep.net/speedo.html" target="_blank">http://www.gotjeep.net/speedo.html</a>
93' YJ
00' TJ
02' KJ
04' Dodge Ram
"Jeep mechanic wanted: must be able to put square peg in round hole"
Atropine is offline
post #3 of 11 Old 03-27-2002, 09:49 AM Thread Starter
Rzrseg
Excellent! Many thanks!
It doesn't have quite the ratio I'm looking for but now I know exactly what to ask for.
Very cool!
Rzrseg is offline
post #4 of 11 Old 03-27-2002, 02:29 PM
Missin44
order part #52067639 at your local dealer. its a 39 tooth gear. you sure about those gears? Sorta and odd set up from what I've see on the board.
'92 YJ, 4.0L, 5 spd, OX Locked front, 4:10 gears, BDS 3.5" lift, reverse shackles, Ford 8.8 Limited-slip rear, York OBA, JB Conversions SYE Kit, CV driveshft, Centerforce II clutch, Big Daddy Step Rock Rails, Skid Row Top Prop, Big Daddy OffRoad Front Bumper, Yokahoma Geolander 32's, Rokmen Riddler differential cover
Missin44 is offline
post #5 of 11 Old 03-27-2002, 03:00 PM Thread Starter
Rzrseg
</font><blockquote><font size="1" face="Verdana, Arial">quote:</font><hr /><font size="2" face="Verdana, Arial">Originally posted by Missin44:
<strong>order part #52067639 at your local dealer. its a 39 tooth gear. you sure about those gears? Sorta and odd set up from what I've see on the board.</strong></font><hr /></blockquote><font size="2" face="Verdana, Arial">Thanks. No, I'm not completely sure about the setup. It's what the guy I bought it from said was on it. I'll do the "jack it up and rotate the tire test" here shortly to make sure. I also have all the paperwork from everything ever done to the jeep so maybe it's in there also....but I'll do the tire check anyway.
Rzrseg is offline
post #6 of 11 Old 03-27-2002, 03:56 PM
Missin44
That will work, first check the diff. cover for a metal tag will have some numbers on it, That will also tell you your ratio. BTW, make sure you check BOTH covers. When I bought mine the rear had been changed to a 4:10, the front hadn't and was still 3:07
Missin44 is offline
post #7 of 11 Old 03-27-2002, 08:26 PM Thread Starter
Rzrseg
</font><blockquote><font size="1" face="Verdana, Arial">quote:</font><hr /><font size="2" face="Verdana, Arial">When I bought mine the rear had been changed to a 4:10, the front hadn't and was still 3:07[/QB]</font><hr /></blockquote><font size="2" face="Verdana, Arial">Oh yeah, I had a question about that. I'm thinking this is what I'm going to find. He had air lockers on both (there are two switches on the dash) but said the rear one was making it drive funny so he took it off and now it has 4.61's back there. I didn't think much about it at the time but now I'm pretty sure I'm going to find different ratios between the front and rear. Is there any problem with this?
Rzrseg is offline
post #8 of 11 Old 03-28-2002, 11:17 AM Thread Starter
Rzrseg
Anyone? Anyone?
Bueler? Bueler?
Rzrseg is offline
post #9 of 11 Old 03-28-2002, 02:11 PM
rodgersmc
I'm no expert on this, but I thought if you had different ratio's you'd get chaffing or slipping... that is, they won't move quite in tandom causing a slip occasionally. It will hurt tire life and jerk you a bit.
But if you're driving it and not feeling any of that, then I'm not sure. Maybe it would only happen when in 4x4.
89 YJ 4.2L
3" body lift
2" shackle lift
32" tires on 15X10's
winch
soon to be JKB2 mod
rodgersmc is offline
post #10 of 11 Old 03-28-2002, 02:36 PM
Missin44
If they are differant, huge problem if you engage 4wd. You could ust transfer case, drive saft, tranny, etc. 2wd its ok. Still 4:61 seems wrong, never heard of that ratio
Missin44 is offline
post #11 of 11 Old 03-28-2002, 08:04 PM
4wheeler4CJ
4wheeler4CJ's Avatar
Could you just drive by one of those stupid Mobile Laser Radar Detectors, that the cops leave on the side of the street and compare how far off you are and live with it? LOL
How many of you out there just punch it when you see those things to see how fast you can go before you pass it? <img border="0" title="" alt="[Eek!]" src="eek.gif" />
4wheeler4CJ is offline
What is preferred method to correct speedometer on my 06 Rubicon LJ? CB3 TJ Wrangler Technical Forum 33 03-14-2009 11:41 AM
What can be used to correct my Speedometer after putting in new gears? Kenbo-Slice TJ Wrangler Technical Forum 32 10-28-2008 08:25 PM
Which is correct? (speedometer gears) EDGEY TJ Wrangler Technical Forum 5 06-15-2007 06:40 PM
Bigger tires...what piece do I need to correct my speedometer? 05 Rocky Mounta TJ Wrangler Technical Forum 11 02-21-2007 08:00 AM
Can anyone explain how you can correct the speedometer after you install larger tires blackjeep04 TJ Wrangler Technical Forum 2 05-23-2004 06:22 PM
