coolant temperature sensor '89 YJ 2.5L - JeepForum.com
post #1 of 12 Old 01-07-2009, 05:03 PM Thread Starter
pyrobyro
Howdy everyone. Looks like my sensor may be dead since my gauge is no longer registering any heat. My manual is not very descriptive as to where to find the sensor, other than it is in the thermostat body. Can anyone do a walkthrough on this for an idiot like myself? It will be much appreciated!!!
pyrobyro is offline
post #2 of 12 Old 01-07-2009, 05:16 PM
RoscoeJ
If your talking about temp sensor its on the drivers side near the firewall ,on your manifold.
RoscoeJ is offline
post #3 of 12 Old 01-07-2009, 05:29 PM Thread Starter
pyrobyro
coolant temperature sensor vs. temperature sending unit
If my water temp gauge is not registering any temp at all, do I need to start with the sending unit or the sensor? Just a little confused between the two different systems.
pyrobyro is offline
post #4 of 12 Old 01-07-2009, 06:04 PM
Mean Max
Don't poke the bear
Mean Max's Avatar
I stole this pic from another thread in a post by Burnerman. I hope he doesn't mind!
The pic is of a 6 cylinder 4.2L, but your 2.5L has the gauge sender in the same place on your engine. It has just 1 wire connected to it. It works by grounding the gauge, so if you pull the wire connector off & ground it out the gauge will show it's hottest reading, with the key on of course!
Originally Posted by UltimatE View Post
Max has a picture of every Jeep part ever made.
Originally Posted by Benderff View Post
No one here knows what they are talking about. You should try Pirate 4x4 they will be happy to help you.
There is no situation that cannot be improved with a small but well-placed explosive.
Mean Max is offline
post #5 of 12 Old 01-07-2009, 08:09 PM Thread Starter
pyrobyro
Great! I found it and will replace the sending unit tomorrow. The picture saved the day!
pyrobyro is offline
post #6 of 12 Old 10-30-2009, 09:03 AM
roadhog481
thanks for the pic. i almost pulled the knock sensor
roadhog481 is offline
post #7 of 12 Old 12-27-2012, 12:23 PM
veitski87
I know this is an old thread but I am having a problem with a conversion and need to know what the one circles in red is is that the gauge sender? And if I ground it. Does it always stay at the hottest?
Freedom Jeep- 92 YJ 4.0HO AX-15
veitski87 is offline
post #8 of 12 Old 12-27-2012, 01:23 PM
flcracker
yes....
flcracker is offline
post #9 of 12 Old 12-28-2012, 07:26 AM
veitski87
And the solution would be? I have a 98 4.0 I put in.
post #10 of 12 Old 08-07-2013, 11:32 AM
spooky1
im replacing all of my factory guages> with mechanical guages because the circuit stirp is bad and opens up on occasions high temp,low temp aka weather changes. so out with them> it was not a good a design from the factory its supposed to last forever!! or at least as long as the jeep still runs!!
www,surpluscenter.com ask for niki/nicole mariscal!! great service, fast delivery, very fast from nebraska to georgia! call early it may ship same day?? middle of america.
(i am not connected/own/or what ever to surplus center) just nice folks!
since i live remote 40 miles round trip into a store, its easier /cheaper to order on line> even with shipping cost its cheaper!
spooky
spooky1 is offline
post #11 of 12 Old 08-07-2013, 11:40 AM
spooky1
ps:buy a year engine specific shop manual>> bite the bullet ! pay the price!
its pays in the long run to have the correct manual>> just like good tools,(i have a ripsaw from 1957) calipers from 1934(still calibrates perfectly) even my o=scope 1973 also bullet proof .
all of the good tools and correct products pay off, life tools with a life time guarantee .
spooky1 is offline
post #12 of 12 Old 08-09-2013, 12:27 PM
veitski87
Yeah I just bypassed the stock sensor and got a splice kit that taps off the fluid in the radiator hose. Works great.
coolant temperature sensor ? k2beach TJ Wrangler Technical Forum 5 12-29-2009 06:44 PM
Coolant Temperature Sensor Bystander TJ Wrangler Technical Forum 2 05-01-2009 08:09 PM
Coolant Temperature Sensor Connection Help Urb4nTr0ll YJ Wrangler Technical Forum 2 11-14-2008 07:45 AM
Coolant temperature sensor jeepsurf YJ Wrangler Technical Forum 8 06-12-2008 06:43 PM
Measuring coolant temperature and sensor issue The Buck YJ Wrangler Technical Forum 2 07-12-2006 05:08 PM
