Coolant Problem - JeepForum.com
post #1 of 9 Old 11-29-2011, 09:57 AM Thread Starter
leblanj
Coolant Problem
Just rebuilt everything for my 88 wrangler 4.2 258. It ran great for about 550 miles after rebuild, then the water pump started to leak. I changed the water pump and now the coolant is filling into the overflow tank and spraying all over the engine compartment after driving a mile or so down the road. All the hoses are connected correctly. I just changed the head gasket and test drove it again and I will get a mile down the road and the same problem will occur. It will not happen when it is idling in the driveway. This is our only problem with the jeep and we are out of ideas on what to try next.
leblanj is offline
post #2 of 9 Old 11-29-2011, 10:07 AM
jbolty
jbolty's Avatar
Is it v belt, or serp? If serp, you may have gotten the wrong rotation water pump.
The cap should hold pressure up to about 15 psi before releasing water to the overflow.
jbolty is offline
post #3 of 9 Old 11-29-2011, 10:17 AM
Old4X
1990 CJ7
Cracked head or block. Did you bore the cylinders oversize?
418 miles on 19 gallons of gas. Can't beat the BBD !
Old4X is offline
post #4 of 9 Old 11-29-2011, 10:32 AM Thread Starter
leblanj
It is a v belt. Radiator is new along with the cap.
leblanj is offline
post #5 of 9 Old 11-29-2011, 10:35 AM Thread Starter
leblanj
Had to bore the cylinders .30, we lost compression earlier this year and thats why we rebuilt the motor.
leblanj is offline
post #6 of 9 Old 11-29-2011, 10:53 AM
Cooter92YJ
It's got to have something to do with the new water pump, whether like J-Bolty said wrong rotation or just plain the wrong one. Didn't do it before the new one, right?
Cooter92YJ is offline
post #7 of 9 Old 11-29-2011, 11:01 AM Thread Starter
leblanj
Same water pump by part number and this issue has never occurred before.
leblanj is offline
post #8 of 9 Old 11-29-2011, 11:02 AM
moonshinefuel
Maybe the thermostat is not opening.
AX5/NV3550 Conversion Thread.
Bow Hunting
moonshinefuel is offline
post #9 of 9 Old 11-29-2011, 12:26 PM
hotelconucc93
hotelconucc93's Avatar
2010 YJ Wrangler
To see it happen, you might have to idle it in the drive......but...make it happen. Work the throttle and rev it to 2000 and hold it while you watch.
Axles and bolts and springs....Oh My!
My Build Thread --->>>
Not my write up, but now one of my jeeps losing a BA and gaining an AX->
hotelconucc93 is offline
Disappearing Coolant Problem couesfanatic TJ Wrangler Technical Forum 9 07-23-2010 02:46 PM
Coolant Problem 69MelMan TJ Wrangler Technical Forum 9 05-30-2010 10:24 PM
Coolant/possible head problem. Need help! MalevolentChewy TJ Wrangler Technical Forum 9 05-17-2010 02:26 PM
If Anyone Has had This Problem, Please Help! Coolant temp./Gauge problem tjbrotha TJ Wrangler Technical Forum 2 06-03-2009 01:14 PM
Coolant Explosion Problem onebigtj TJ Wrangler Technical Forum 6 10-26-2005 12:59 PM
