Coolant leaks please help - JeepForum.com
post #1 of 5 Old 06-05-2002, 09:58 PM Thread Starter
KYgreenYJ
I get a new coolant leak about every month, i have a new radiator and a rebuilt water pump(i guess i doubt they put a new one in). everytime i turn around tho i have another hole in a hose and its really starting to get annoying. Today i walked out side after goign in for a few minutes and there was a 3/4's inch long hole in the top main hose spewing out the green stuff. anybody have this problem or know what i can do about it.
Black 2012 JKUR 2.5" Rock Krawler Max Travel suspension with Bilstein 5100's, 35X12.5R15 MTRK's on MB Ultras, Sleeved and gusseted front axle with Synergy balljoints, JCR bumpers F/R
Old Jeep, SOLD:
94 Green YJ SE 4.0L 5spd
3.5" BDS lift, 1"MML/BL, Revolvers, SYE/CV, no track bars or sway bars, MORE sport cage
Green Jeep Club Member #20
KYgreenYJ is offline
post #2 of 5 Old 06-06-2002, 12:40 AM
kidwired
kidwired's Avatar
get new hoses before it leaves you stranded on the trail, they must have used cheap crap. goodyear makes some EXCELLENT hose. try napa, kragen and the like will not have it
94 yj SOA +3.5", 35" swampers.
kidwired is offline
post #3 of 5 Old 06-06-2002, 07:48 AM
hog
If all your hoses are new (even if the are cheap) you should not be blowing them, sounds like a pressure problem. Dumb question when they replaced the radiator, did they put a new cap on (ie pressure relief and is so was it the proper rating?)
Hog
hog is offline
post #4 of 5 Old 06-06-2002, 09:55 PM Thread Starter
KYgreenYJ
yeah tis a new cap that wil release pressure, and yeha they are cheap hoses form pepboys but i mena shouldn't they last a little longer then 3 months a piece
Old Jeep, SOLD:
post #5 of 5 Old 06-06-2002, 11:27 PM
moabster
moabster's Avatar
2011 WK
Another thing to check. If you are getting leaks close to the clamps you may be tightening the clamps too tight and cutting into the hose.
2000 Jeep Grand Cherokee V8 Stock
93 YJ I6 hard top (really belongs to SPEED)
RE 4.5" Extreme Duty Lift, Advanced Adapters SYE, Tom Woods CV Drive Shaft, EA589 10" rims with 33" x 12.5" MT/Rs
Bullet Proof Front and Rear Bumpers and Tow bar
moabster is offline
huge coolant leak/ creamy coolant?? 11Bgixx TJ Wrangler Technical Forum 17 01-11-2010 09:24 AM
Leaks fixed in one spot, now I got 3 new leaks in new spots yay MacK JK Wrangler Technical Forum 5 11-08-2008 08:20 AM
losing coolant...no visible leaks TXST8tj TJ Wrangler Technical Forum 19 01-26-2008 05:46 AM
Leaks Leaks Leaks from my 4.2, question olyjeep YJ Wrangler Technical Forum 9 03-13-2007 12:26 PM
Got LEAKS? nickva YJ Wrangler Technical Forum 3 08-05-2003 08:55 PM
