Coolant leak - Hope someone has some insight - Page 2 - JeepForum.com
post #16 of 19 Old 02-24-2013, 10:33 AM
Speedymcracer01
Originally Posted by Rproject View Post
While you're right there, you may want to check the condition of your fan clutch and replace that if it's wobbly. 4 bolts and you're home free. As long as you're in the neighborhood .......
Got four bolts to the fan blades then four nuts holding the clutch
Speedymcracer01 is offline
post #17 of 19 Old 02-24-2013, 10:37 AM
Speedymcracer01
Originally Posted by dkirkley View Post
Hey everyone,
I got a coolant leak on my 93 YJ 2.5 the other day and it was a pretty fast leak.
After leaving it alone a few days most of the coolant was gone and when I checked under it looked like the leak was out of the lower radiator hose.
I removed the old one and didn't find much wear or any cracks. I replaced it anyway.
I recently replaced the upper radiator hose and the heater hose as well because those had cracked.
Anyway,
Besides those three hoses I don't know where else to look. Anyone have insight? It drips from the front of the oil pan right next to the belt and the top end doesn't appear to be damp at all.
Here are some pictures. Hopefully I explained it well enough. Maybe the water pump or something?
Just make sure you salvage the bolts that are on the water pump not the mounting bolts the ones that has nothing but threads that you bolt the fan clutch to my water pump didn't come with any
post #18 of 19 Old 02-25-2013, 01:44 AM Thread Starter
dkirkley
Yeah I read that it's highly recommended to replace the fan clutch while i do the pump. $25 for the pump and $35 for the fan clutch. All in all won't be too bad but I have to do it Thursday on payday. I'm stuck on my bike right now and really missing my jeep. Except enjoying not paying for such high gas prices lately
dkirkley is offline
post #19 of 19 Old 02-25-2013, 06:19 AM
Mark05059
when you get your new pump they make a kit for the studs. Much easier to just buy the new ones then try and get the old ones out
1998 ZJ 5.2 Auto
1989 Wrangler Black Bone Stock 2.5l 5spd
/l , [____],
|---L--[]lllllll[]-
()_) ()_)==O=)_)
Mark05059 is offline
