Coolant leak help - JeepForum.com
post #1 of 7 Old 09-14-2011, 06:30 AM Thread Starter
lkostenbader
Coolant leak help
So last night when I was walking our of the store I saw a small puddle of coolant forming under my jeep. After looking around the engine bay I saw it was coming out of a little spout that's located under the battery holder. Its at about 10-15 drops a minuet. It also is leaking from the inside on the passenger side from under the heating vent. I have no idea what i would need to fix or replace. My buddy said the spout might be a overflow spout for an overflow coolant tank but he wasn't sure. Any ideas?
(Pics not of my jeep) but that's where the spout is.
lkostenbader is offline
post #2 of 7 Old 09-14-2011, 08:08 AM
tydp
leak
Heater core is leaking.....you will have to remove the "heater box" inside the Jeep. Heater core is inside the heater box...
tydp is offline
post #3 of 7 Old 09-14-2011, 08:16 AM
nembudonna
Heater core rusted through or a hose leaking.
nembudonna is offline
post #4 of 7 Old 09-14-2011, 08:46 AM
tdewit
That's going to be fun while the dash is in................
tdewit is offline
post #5 of 7 Old 09-14-2011, 10:18 AM
Cooter92YJ
The spout is a drain from your heater/ac box that allows condensation to drain outside of the cab. If it is coolant, then x2 on the heater core going bad on you. They are not that hard to change out, but just in case, do check the heater hoses to be sure they are tight. They could leak enough to run inside, the out the drain.
Cooter92YJ is offline
post #6 of 7 Old 09-14-2011, 07:46 PM Thread Starter
lkostenbader
Thanks for the input. Gana go grab a new heater core at Napa and swap it out in the morning and hopefully it will be good as new.
post #7 of 7 Old 09-14-2011, 09:56 PM
timatoe
timatoe's Avatar
It's not bad to replace, look in the FAQ's, there's a good write up in there.
Edit: Here ya go.... http://www.jeepforum.com/forum/f12/heater-core-219329/ Might also replace the blower motor since you're already in there. I did the motor and not the core and about three months later the core started leaking...
timatoe is online now
Sweet Coolant Smell but No Coolant Leak? JB73 TJ Wrangler Technical Forum 4 11-07-2010 10:56 PM
I see coolant I smell Coolant But can't find leak. MrB TJ Wrangler Technical Forum 23 07-18-2010 06:33 PM
huge coolant leak/ creamy coolant?? 11Bgixx TJ Wrangler Technical Forum 17 01-11-2010 09:24 AM
coolant leak dieseldogpi YJ Wrangler Technical Forum 3 01-11-2007 10:11 PM
Coolant Leak frodare TJ Wrangler Technical Forum 5 05-15-2006 06:43 AM
