Coolant leak - JeepForum.com
post #1 of 8 Old 06-13-2013, 03:26 PM Thread Starter
yjgirl88
Coolant leak
Hi everyone,
I have a '94 YJ and I am having an issue with coolant leaking. Bought it a few days ago knowing there was a leak. Brand new water pump, installed by previous owner who didn't remove the old WP gasket, so we pulled that out and put a new one in. New thermostat as well. Now, the engine is staying cool but we are still seeing a small leak. Can't get in to see exactly what the issue is yet, but any suggestions on where to look? Anything that is a common issue?
Thanks!!
yjgirl88 is offline
post #2 of 8 Old 06-13-2013, 03:41 PM
Rproject
1987 YJ Wrangler
You're going to have to trace out the leak trail. It could be from your hoses, maybe a clamp isn't tight enough? Are you sure the gaskets are properly seated for the thermostat and water pump?
1996 White ZJ
1987 Maroon YJ (sideways build)
1996 Forest Green XJ
The "sideways" build thread:
Rproject is offline
post #3 of 8 Old 06-13-2013, 03:42 PM
idaholtby
Could you please be more descriptive as to the location of the leak. Most non-descript answers go for the water pump, but obviously you have addressed this. Drops seen underneath is from what locale? Front of engine, left/right, near firewall, etc...
idaholtby is offline
post #4 of 8 Old 06-13-2013, 04:12 PM Thread Starter
yjgirl88
Front of engine, area of where the WP gasket is.
yjgirl88 is offline
post #5 of 8 Old 06-13-2013, 04:29 PM
idaholtby
The only answer I could provide then is to crawl under the beast after it has been warmed up and then shut off. Coolant pressure is at it's greatest at this point of time and provides the best chance of catching it in action. If the water pump is not the source, as it has been replaced with new, then look at all hose connection points and then the radiator itself, as it can spray in any direction from a breach.
post #6 of 8 Old 06-13-2013, 06:02 PM Thread Starter
yjgirl88
A farther out view for area comparison
Closer up
yjgirl88 is offline
post #7 of 8 Old 06-13-2013, 06:04 PM Thread Starter
yjgirl88
Those pics are taken from the drivers side.
yjgirl88 is offline
post #8 of 8 Old 06-13-2013, 06:07 PM
idaholtby
Well with these pictures, your issue is either a cracked thermostat housing or insufficient thread sealant on the heater tube that is threaded into the t-stat housing.
coolant , Coolant leak , water pump
