Quantcast Converting rear drum brakes to disc brakes - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > YJ Wrangler Technical Forum > Converting rear drum brakes to disc brakes
Old 05-15-2008, 10:39 AM   #1
Urb4nTr0ll
When converting rear drum brakes to disc brakes, do the brake lines that were used on the drum brakes connect to the disc brakes? All I have to do is "change" the drums for disc and that is all, right?
I did find a manual on this, but they just simply connected the old drum lines to the disc brakes.
I need more input and opinion. Thanks.
Urb4nTr0ll is offline   Reply With Quote
Old 05-15-2008, 11:58 AM   #2
93jeepREDSOX
My input is to not waste money on the d35. Converting it to disk brakes is a big waste of money. I think the swap is more involved than that.
1993 YJ 4" RE lift, 1/2" shackles, AA SYE Kit, 33x12.50 Trxus M/T, Warn bumbers front and rear, Warn M8000 winch, 4 Hella fog lights, Magnaflow cat, flowmaster muffler with no tailpipe, herced tub, tj flares
HOW BOUT THEM REDSOX
My Rigrator score 535RRv1.0 BOA 25
93jeepREDSOX is offline   Reply With Quote
Old 05-15-2008, 12:44 PM   #3
tuckinauster
x2, get an 8.8 with discs already on it... it may end up being more work, but you'll have a much better product when its all said and done.
Sniper Central
Originally Posted by P.J. O'rouke
"The Jeep is a manly device. And a womanly device. An American device. It’s a fitting instrument to transport the free people of a free nation with the respect to which we are entitled and the dignity that we deserve."
tuckinauster is offline   Reply With Quote
Old 05-15-2008, 07:02 PM   #4
xeroid81
Do the later model explorers have discs brakes already on those 8.8's ?
xeroid81 is offline   Reply With Quote
Old 05-15-2008, 07:16 PM   #5
81Sparky
Yes, You will want a 96 or older with the 31 spline axels. It is reccomended to change your master cylinder as well because of the increase brake fluid requirment. Brake lines will depend on the lift of you rig. -Sparky-
uuuuuhhhhh...OK!
81Sparky is offline   Reply With Quote
Glock Forum
