converting-fuel-injection-carb - JeepForum.com
post #1 of 37 Old 11-20-2013, 12:53 AM Thread Starter
prcrup
I have a 1991 Jeep Wranger S that was fuel injected am converting it to carb. few questions, 1) can I keep the fuel pump that is in the fuel tank to supply fuel to the carb as long as i install a fuel regulator in line and bypass the fuel relay so that the pump stays on all the time. 2) on the intake manifold I got it has 2 ports on the top that looks like water ran through .. any ideals on what that might be ?
prcrup is offline
post #2 of 37 Old 11-20-2013, 01:01 AM Thread Starter
prcrup
I have a 1991 Jeep Wrangler S that was fuel injected, I am converting it to carb and had a few questions 1) can I use the fuel pump that is in the tank as long as I install a inline fuel regulator and bypass the fuel relay so that the fuel pump will stay running 2) on the intake manifold I got it has 2 ports on the top that looks like water ran through them, any ideal what it might be ?
Thanks
Paul
prcrup is offline
post #3 of 37 Old 11-20-2013, 01:06 AM
Michaelgoesrawr
Michaelgoesrawr's Avatar
I'm not entirely sure but I don't think you can't bypass the fuel pump relay and have it run all of the time
Michaelgoesrawr is offline
post #4 of 37 Old 11-20-2013, 01:08 AM
Michaelgoesrawr
I don't think you can bypass the fuel pump relay. How would you shut it off when you're not driving? May be a stupid question, but one to think about none the less.
Host a picture of the ports you're talking about on photobucket or a site alike and post the img tag here so we can see what ports you're talking about.
post #5 of 37 Old 11-20-2013, 05:05 AM
roadyrob
1987 YJ Wrangler
i'm not sure on your fuel pump question but if you use a fuel filter with a return line like the one on a carbed 258 wouldn't the pump just keep running? it would never build full pressure.
the ports on the intake manifold are for water, the top hose from the heater core goes to the rear port, the front goes to the motor.
Do everything with a positive attitude, it won't always work but you'll piss enough people off to make it worthwhile.
the voices aren't real but they sure have good ideas.
roadyrob is offline
post #6 of 37 Old 11-20-2013, 07:28 AM
Chase0808
Just wondering, why do you want to go from fuel injected to carbureted? I have a carb and I plan on switching to fuel injected. Is there any problems with it?
Sent from my YJ
Chase0808 is offline
post #7 of 37 Old 11-20-2013, 07:59 AM
Old4X
1990 CJ7
You will need a solenoid switch powered by the ignition circuit to operate the pump.
Not sure you can get a regulator that will drop pressure to under 4 PSI that is needed for a carb.
How are you going to run your ignition? Tachometer, speedometer, alternator regulator, etc? These things need the computer.
418 miles on 19 gallons of gas. Can't beat the BBD !
Old4X is offline
post #8 of 37 Old 11-20-2013, 08:26 AM
tom_sprecher
^^^ This. Run pump off ignition or switched. A adjustable Holley regulator like this would work fine.
The ECU, I don't know if there are safety functions for fuel management that would have to be disabled.
Like mentioned above, the big question is why do you want to switch?
Tom
tom_sprecher is offline
post #9 of 37 Old 11-20-2013, 08:43 AM Thread Starter
prcrup
Sent from my YJ
I can not get the coil to fire .. have changed everything .. crank sensor, computer, distributor switch plate, coil, and still have no spark .. nothing but problems with the fuel injection to many problems can happen, one sensor goes bad and jeep shuts down, go with electronic distributor and carb I take the computer and all sensors out of the equation.
prcrup is offline
post #10 of 37 Old 11-20-2013, 08:46 AM Thread Starter
prcrup
Right now when you turn the key on the fuel pump turns on then turns off until you start the jeep if you bypass the relay it will turn on and stay on till the key is turned off, fuel pump would stay on as long as the key is on
prcrup is offline
post #11 of 37 Old 11-20-2013, 08:49 AM Thread Starter
prcrup
The computer will still be in the jeep, so some of the things will still work .. just not going to have the things hooked up to run the distributor and fuel injection
prcrup is offline
post #12 of 37 Old 11-20-2013, 08:54 AM Thread Starter
prcrup
In the fuel tank there is a high volume fuel pump, can always go and buy a low flow external fuel pump from a auto parts store that will do the job for the fuel if I have to .. and thanks for the info on the ports on the top of the intake manifold
prcrup is offline
post #13 of 37 Old 11-20-2013, 09:53 AM
yjcrawlr
Why would you convert to carb? obviously not for off road or fuel economy.
90 YJ 102 in wb stretch, SOA, dana 60, 14 bolt welded,4.56s, 37in Parnelli jones dirt grips, currie twin stick dana 300, york oba, tractor link traction bar, full custom armor,poison spyder tube fenders, 95Cherokee High Output 4.0
2014 JKU, modified Rubicon Rails, RC stubby with warn 8000m, 2" leveling springs and OME trim spacers, Superchips Flashcal, Spidertrax wheel spacers, rubi shocks, and Lots more mods soon!!!
yjcrawlr is offline
post #14 of 37 Old 11-20-2013, 10:30 AM
Jeepsr4me
U verified that the dist is rotating when u crank the engine? Cause the efi on jeeps is bone simple.
Jeepsr4me is online now
post #15 of 37 Old 11-20-2013, 10:45 AM
superj
i would definitely fix the fuel injection too. and i have a carb and like it alot
I don't feel like working on anything at this time so i sold my yj.
superj is offline
