Converting ax5 to ax15 - Page 2 - JeepForum.com
post #16 of 20 Old 05-14-2014, 04:22 PM Thread Starter
Hoddymcc
Clutch disk issues
Delays keep coming about because of work. What clutch disk is needed for the conversion? Ax15 has 10spline and ax5 has 14 spline. Disk diameter changes also, will the flywheel need changed as well. Diameters are 9.125 and 10.5 for the ax15. Any help with this issue.
Hoddymcc is offline
post #17 of 20 Old 05-14-2014, 05:22 PM
Opihi59
from here it gets rough
Opihi59's Avatar
The writeup in the FAQ referenced a 9" 10-spline clutch with PN RCF584 from NAPA. Should use your original flywheel Part number. "Factory flywheel and pressure plate."
You have read THIS, right? It's all in there, pretty complete. Just no pictures though.
....I'm not smart, but I can lift heavy things.......
Fill out your PROFILE, and don't forget to look in the FAQ for writeups
I'm stuck on da Rock
Originally Posted by Brian4.2 View Post
We will be going Metric every inch of the way.
Originally Posted by 40dog View Post
yes I'm a some guy and have always put gasket sealer on my surfaces before mating
Originally Posted by Virjeep View Post
You should go to Pirate. I hear they are real smart over there. You'd fit right in.
Opihi59 is offline
post #18 of 20 Old 05-15-2014, 03:59 PM Thread Starter
Hoddymcc
Yes I did. Napa doesn't offer that part . Not shown in system. Thought I would ask others, write up doesn't state vehicle part was for. Will investigate more. Thanks for your help, I do appreciate all the feedback. Summit ridge has the disk needed. Will post part numbers when received and verified all is well.
Hoddymcc is offline
post #19 of 20 Old 05-15-2014, 05:21 PM
Opihi59
Opihi59's Avatar
Hmmmmmm. I can't google that number up from work at present and see if it cross-references. What is the clutch that is used on the 90's Dodge that came with the 4 cyl and the AX15? Is that the 9" 10-spline unit?
Try and google up that part number and look for a cross ref. It's bound to be out there.
Opihi59 is offline
post #20 of 20 Old 05-16-2014, 08:19 AM
StanF
I used Sachs BBD4198 from Rock Auto...
StanF is offline
ax15 , YJ
