constant power at fuse block? - JeepForum.com
post #1 of 4 Old 08-01-2012, 07:15 PM Thread Starter
mitchs1224
do any of the fuses of an 89 yj have constant 12v's with ign off? my circuit tester says yes but a previous post on here says that this models fuse block doesn't have any constant feeds? only in the switched position does it have 12v's?? I'm trying to track down a problem with a stereo and this may be the problem?
mitchs1224 is offline
post #2 of 4 Old 08-01-2012, 07:31 PM
Desert_Rampage
1991 XJ Cherokee
I believe all of them are switched...
"Chainsaws can dismantle anything... Or you can just take it apart by removing screws until it opens, but what fun is that? "--Motoman22
Desert_Rampage is offline
post #3 of 4 Old 08-01-2012, 08:57 PM
90DesertTanYJ
Try your Dome fuse and the clock fuse
90DesertTanYJ is offline
post #4 of 4 Old 08-03-2012, 07:22 AM
Que89YJ
Que89YJ is offline
constant whine coming from power steering? Utfan010 TJ Wrangler Technical Forum 22 08-25-2010 10:55 AM
Adding and AUX Fuse block and Relay Block letitloose06 YJ Wrangler Technical Forum 2 07-23-2010 08:38 AM
Wiring Question- Constant power plug josh1997tj TJ Wrangler Technical Forum 2 05-15-2010 03:32 PM
89 YJ Fuse Block VacaDuck YJ Wrangler Technical Forum 1 12-26-2008 02:18 AM
constant POWER wick913 TJ Wrangler Technical Forum 5 09-07-2008 02:43 AM
