Connecting rubber fuel line to factory hard fuel line??? - JeepForum.com
post #1 of 8 Old 04-10-2013, 08:57 PM Thread Starter
FiremanBrian
On my project, here's my dilemma...I had to cut off the last 5 or 6 inches of steel line after fuel filter towards motor...so now I have the 3/8" rubber line coming off of fuel filter and need to "adapt" it to the seamless hard line w/o a flared end to "grab" the rubber line...
It looks like the factory hard line is 1/4"?
Where to find a 1/4" to 3/8" barbed adapter like a Push-Lock type Bite fitting? I've googled for over an hour now and can only come up with applications for water misting systems, nylon push locks, etc...
I need a good old steel adapter...any help from you guys please?
Or since it's late am I overthinking this? What have you guys done for a similar problem? Just get a 1/4" rubber fuel line and clamp the hell out of it?
FiremanBrian is offline
post #2 of 8 Old 04-10-2013, 09:22 PM
deathtrap
I have flaired the end of the steel tube by doing the first step of a double flair. it makes kind of a bubble on the end for the hose and clamp to grab.
deathtrap is offline
post #3 of 8 Old 04-10-2013, 09:49 PM
SeanB95YJ
in the past (not on the YJ but same process) I went a step further than deathtrap... I put a flare fitting on the line and double flared it... then got a flare to barb fitting to attach to the rubber line
Sean B. - Schenectady, NY - 95 YJ, 350/700r4/NP241, JB Shorty SYE, 8.8 rear, 2" BDS, 1" homebrew shackles, Daystar 1" BL, TJ flares, 35x12.50 General Grabber AT2 on 15x10 Bart D-Truckers, Polyshield polycarbonate windshield, HD over/under crossover steering
swap/build thread:
SeanB95YJ is offline
post #4 of 8 Old 04-11-2013, 10:32 AM
Old4X
1990 CJ7
You can get a fitting that goes into the carb inlet nut with either an AN fitting on it or a hose barb.
418 miles on 19 gallons of gas. Can't beat the BBD !
Old4X is offline
post #5 of 8 Old 04-11-2013, 02:09 PM
jr4x4
I got mine at autozone. Screwed it in top of fuel pump on my 4.2 and pushed a rubber hose on. Home depot dont have that size brass fitting
jr4x4 is offline
post #6 of 8 Old 04-11-2013, 04:44 PM
mike_breaker_5
i used rubber fuel line and 2 hose clamps to span b/n the factory steel line and the hard line i ran to the tank... been holding for 2 years so far.
stretch the rubber line over the steel line, seal it with a hose clamp, drink a beer.
Ratmonkey donation page. all proceeds will go to his family.
it's not much to look at... but it's mine.
5.2lswap, metalcloaks, bedliner, tucked belly, d60's, soon to be nv4500 and d300.
mike_breaker_5 is offline
post #7 of 8 Old 04-11-2013, 06:29 PM
laybackman
Bikini Bridge Inspector
laybackman's Avatar
2010 JK Wrangler
Make sure the hose is rated for fuel injected use.
Do you know what was good about the good old days? I wasn't good, And I wasn't old!
Senators and Congressman should wear uniforms like NASCAR drivers so we could identify their corporate sponsors....
laybackman is offline
post #8 of 8 Old 04-11-2013, 08:24 PM Thread Starter
FiremanBrian
Thanks guys
Several good responses, so thank you for helping...
This turned out to be stainless steel, so there was no way a flaring kit was ever going to put a double flare on it, so, after some thinking today here is what I came up with....
My rubber line was 3/8", that steel line was 1/4"...just too much space for a clamp to try to overcome...so, I scraped the rubber line altogether on the motor side of the filter and bought another section of 1/4" flared reg steel line and used a compression fitting to "mate" the two, on the other end searched for the fittings I needed and bought a GM screw in fuel filter...
So now, I have all steel line and fittings coming out of the fuel filter heading towards fuel rail, ALOT more safer in my book, the other end of the GM filter used a screw in barb so I can still plumb up the 3/8" rubber line coming from my fuel cell...
BTW, sorry I left this out...this is a '95 Yj with fuel injection of course
If anyone wants pics I can add them or a parts list of what this took but IMO, doing away with at least that small stretch of rubber line gives me more security...
