compression question - JeepForum.com
post #1 of 5 Old 10-08-2002, 03:30 PM Thread Starter
DanyJeep
DanyJeep's Avatar
hi,
I'd like to know what the compression should be at on a 94 yj 4cylinder mpfi
to my knowledge the compression ratio is 9.2 to 1
and i did a compression test and i got
130, 130, 135, 145,
is this a good compression?
thanx dany
DanyJeep is offline
post #2 of 5 Old 10-08-2002, 03:57 PM
NaeKid
JF Administrator, eh?
NaeKid's Avatar
Some of those numbers are a little low .. they should all be around the 145 to 155 mark (if I remember the numbers correctly). If you have a Haynes manual handy, the compression numbers should be listed in the 4-Cyl statistics page.
I am at work, so I can only go by what I think I remember reading while I was in the ThroneRoom
Hello, my name is Vance and I am a Jeepaholic.
Its better to be naked with your friends, than to be clothed with your enemies
Silver
, zombie ready as the daily-driver
NaeKid is offline
post #3 of 5 Old 10-10-2002, 11:47 AM Thread Starter
DanyJeep
DanyJeep's Avatar
nae kid.....
would you be able to confirm those numbers?
please. i'll tell you why later
DanyJeep is offline
post #4 of 5 Old 10-10-2002, 12:03 PM
RCHavok797
RCHavok797's Avatar
From the Haynes manual: Cylinder compression pressure should be between 155 to 185 psi.
2005 LJ Impact Orange 4.0L Automatic (Tigger) - new ride
1991 YJ Sahara 4.0L Automatic
1978 Dodge Lil Red Express - work in progress
RCHavok797 is offline
post #5 of 5 Old 10-10-2002, 12:57 PM
Newfie
As long as all the cylinders are resonably close, you shouldn't have any issues. An older motor will not have anywhere near the compression that it came from the factory with. It's when you get 1 or two cylinders that are way out from the others that you need to worry. Your's are not completely unreasonable, but my guess is that it's almost time for new rings.
No officer, that wasn't an accident. I did that on purpose...
Newfie is offline
low compression cyl 1 wanabejeeper YJ Wrangler Technical Forum 7 09-21-2009 04:42 PM
compression question on 4.2L I6 m_t_r_86 YJ Wrangler Technical Forum 1 06-24-2009 01:20 PM
Full compression in front, no compression in rear Caceman YJ Wrangler Technical Forum 5 05-20-2009 07:00 PM
Compression test procedure question keithert TJ Wrangler Technical Forum 4 09-07-2006 10:07 PM
Over Compression??? bcridez TJ Wrangler Technical Forum 4 11-28-2004 02:10 PM
