compression low ? - JeepForum.com
post #1 of 6 Old 08-26-2013, 02:21 PM Thread Starter
cody413
compression low ?
I have a 92 wrangler. I just got a head job on it. And they said the compression is running all 95. Is that good? It has 138k on it. And its still running like wanted to stall when I give it gas. Then suddenly stalled and won't start now. Always something after the shop
cody413 is offline
post #2 of 6 Old 08-26-2013, 02:24 PM Thread Starter
cody413
Also its a 4 cylinder.
cody413 is offline
post #3 of 6 Old 08-26-2013, 02:34 PM
jokerchief462
Should be closer to 150 when hot. I would recheck what you had done if it won't start or have them call a tow truck and fixi it.
89YJ 2.5L TBI, AX-5, NP231 SYE, Ford 8.8, Yukon Grizzly, Tom Woods Shaft, 33" BFG T/As, 4" lift, Warn VR10000s.
AF Jeep Club Tail #184
jokerchief462 is offline
post #4 of 6 Old 08-26-2013, 04:59 PM Thread Starter
cody413
I got it home. I just tried starting it. Started fine ran goid around the block. But now I have to worry about is it gonna make me to work or not. Idk what would make it bog out when giving it gas.?
cody413 is offline
post #5 of 6 Old 08-26-2013, 05:01 PM Thread Starter
cody413
I got it home. Started up fine. Ran good around the block. What could make it want to bog when giving it gas?
cody413 is offline
post #6 of 6 Old 08-26-2013, 05:24 PM
Luuca
Typical /f12 Hooligan
Luuca's Avatar
Cody, please fill out your vehicles profile as completely as possible.
Here's what I found on a quick search:
Originally Posted by Que89YJ View Post
Sputtering could be a few things. If its still bad vacuum leak like RR said; use a can of brake cleaner or starter fluid and lightly spray around the hoses and intake listening for an idle change.Tune up: plugs,cap,rotor,wires, and fuel filter and clean the throttle body. Last but not least TPS and O2 sensor. Try them in order. RR and I have the same 2.5TBI and its a little bit more of a pain to troubleshoot without the diagnostics
If it bogs down on throttle, I would check the above as Que stated first and then Search The Forums for TPS diagnostics, there are several very good posts to help you determine if the TPS is bad. What type and what tests you run depend upon Automatic or Manual trans.
91 YJ "Alice" 4.0L, AX-15, NP 231 w/HnT Flange, Adams Driveshafts F/R, 2.5" OME 36Rs, 5/8" /f12 Booms, 32" Yoko ATs, 4.10 D30/35 Aussie Lockers F/R
YJOTM never
05 LJ Rubicon "Ghost"
Luck Favours The Prepared
Luuca is offline
