compression check - Page 2 - JeepForum.com
post #16 of 16 Old 09-14-2013, 11:55 PM
Que89YJ
No, it is nothing more then squirting a little oil into the cylinder when you do the compression test if your numbers are low and seeing if they come up. It tells you if the rings are bad.
Fault codes:
Mean Max pics of everything:
No Start:
Que89YJ is offline
