Completed External Slave Swap - JeepForum.com
post #1 of 1 Old 08-28-2006, 02:05 PM Thread Starter
rbn1357
rbn1357's Avatar
I can't believe it is finally done! I have wanted to do this for a long time and finally had the chance to do the upgrade. My tranny went out so while it was down I ordered some parts and now I have a external slave. BTW i have a 1993 2.5L.
Parts Needed: I used all 94/95 parts. They are the same.
94-00? Bellhousing
Hydraulic Clutch assembly
Release lever (i called it the fork)
Release bearing
Spring Clip
Pivot ball
Assembly
It is pretty straight forward. The release bearing clips on to the fork. The fork is held on one end to the pivot ball with the spring clip.
Cost/ Part numbers
$20 Bellhousing #?
$186 Clutch assembly 52104113
$<20 Fork 52107555
$3 Spring Clip 4338855
With all the miscelaneous it was around $240 for the upgrade.
Note: I had to remove the plastic spacer that came on the slave unit. The throw was not far enough with it on (clutch not disengaging enough). I removed it and used some washers. I am currently using two. This half the thickness of the spacer. I will remove one more washer to see if that help a touch more.
Also there is no need to order a new bearing retainer for the ax5 swap. That is only needed on the ax15. I confused myself and ordered the plate. I will send it back though.
rbn1357 is offline
Leans AX-15 External Slave Swap With Pics! Leans93 YJ Wrangler Technical Forum 192 09-15-2017 02:12 PM
External to internal Slave swap, can it be done??? rustywrangler YJ Wrangler Technical Forum 1 12-02-2009 05:32 AM
Help: external clutch slave cylinder swap Blacksmith13 YJ Wrangler Technical Forum 0 02-26-2009 08:47 AM
Swap to external slave Fenix85182 YJ Wrangler Technical Forum 3 09-19-2006 08:50 AM
Internal/External Slave swap TellyDSP YJ Wrangler Technical Forum 13 05-04-2005 08:26 PM
