Completed 8.8 swap. Driveline vibration need help - JeepForum.com
post #1 of 34 Old 03-31-2013, 02:47 PM Thread Starter
1993sahara
Completed my 8.8 swap the other day, stayed sua with 2.5inch lift. Apparently I didn't set the pinion angle right when we welded the spring perches on because I had some serious vibrations and binding when fully extended.
So we stuck in some 4 degree shims and now most of the vibrations are gone but I still feel some in the gas pedal and shifter knob. I am thinking of trying some 5 degree shims next to see how it changed.s.
Anyone have any suggestions. I have a slip yoke eliminator and cv shaft
93 Sahara 4.0, ax15, BDS 2 inch springs, MORE greasable 5/8hd shackles, Ford 8.8 rear, AA sye, Quigley cv shaft, 32" wrangler mtr with Kevlar
_____
/l ,[___],
l--L --[]lllll[]-
()_) ()_)-o-)_)
1993sahara is offline
post #2 of 34 Old 03-31-2013, 03:02 PM
Anticanman
RIP one good jeeper
Anticanman's Avatar
Pics?
Luck Favours The Prepared
Anticanman is offline
post #3 of 34 Old 03-31-2013, 03:17 PM Thread Starter
1993sahara
Pics?
I'll try to snap some tonight when I get off work
_____
/l ,[___],
l--L --[]lllll[]-
()_) ()_)-o-)_)
post #4 of 34 Old 03-31-2013, 03:27 PM
linusb
Sounds like you are on the right track. Put an angle finder (real one or phone app) on driveshaft and the bottom side of the 8.8. They need to be the same erring slightly with pinion being angled lower by a degree.
Once you get measurements determine how much shim you need.
1994 YJ Wrangler, 4.0, AX15, NP231, 35x12.50x15 BFG KM2s, 4" RC lift, 1" lift Boom Shackles, 1" BL, 4.10 gears, 8.8 LSD in rear and D30 Aussie Locker in front, on-board air conversion, Ramsey RE8000 winch.
linusb is offline
post #5 of 34 Old 03-31-2013, 03:40 PM Thread Starter
1993sahara
Where should I hold on the 8.8 housing? The flat spot directly below the flange on the pinion ?
_____
/l ,[___],
l--L --[]lllll[]-
()_) ()_)-o-)_)
post #6 of 34 Old 03-31-2013, 03:52 PM
linusb
That's where I did it and it worked. If you use phone, take it out of case and make sure you zero it out on a level surface. If there is a six inch difference, you'd need half that size shim to bring them equal.
linusb is offline
post #7 of 34 Old 03-31-2013, 04:16 PM Thread Starter
1993sahara
With the 4 degree shims in I got a rough angle on the shaft at 14 degrees and then on that flat spot I got 12 degrees. Does this mean one more degree? So 5 degree shims?
_____
/l ,[___],
l--L --[]lllll[]-
()_) ()_)-o-)_)
post #8 of 34 Old 03-31-2013, 04:18 PM Thread Starter
1993sahara
Here's some pics I could snap. Been raining all day
_____
/l ,[___],
l--L --[]lllll[]-
()_) ()_)-o-)_)
post #9 of 34 Old 03-31-2013, 06:23 PM
Joe Dillard
Electric Chair Operator
Joe Dillard's Avatar
Yep, since you have an SYE & CV rear shaft, the pinion looks to be too low still.
Who did the measuring calculations for the new shaft? It looks to be ~1.5" too short.
Joe Dillard is offline
post #10 of 34 Old 03-31-2013, 06:31 PM Thread Starter
1993sahara
I had to get the shaft cut down, so I took it back to the place that made it with the new measurements and they cut it down.
The the difference in shaft length for my suspension at ride height and extended only changes by 1/2-3/4 of an inch
Do you think the 5 degree shim will be my fix? Only one degree more then I am right now
_____
/l ,[___],
l--L --[]lllll[]-
()_) ()_)-o-)_)
post #11 of 34 Old 03-31-2013, 06:42 PM
linusb
If they make a 5 that's what it sounds like you need. Make sure to use steel shims. If there's no 5 you might try a 6.
linusb is offline
post #12 of 34 Old 03-31-2013, 06:46 PM
linusb
Take a pic of where exactly you placed angle finder. Just in eye balling the spot in the pictures, to me it looks much lower than two degree difference. I want to make sure you are capturing the angle measurement from right spot.
linusb is offline
post #13 of 34 Old 03-31-2013, 06:53 PM Thread Starter
1993sahara
I found one place that makes 5 degree shims but I could get 6 degree shims and change it tomorrow instead of waiting.
I downloaded an app for my phone and used it. Place it on my driveshaft on the back section of it, but on the sleeved part because the actually shaft is too short for my phone.
On the 8.8 I put it directly below the pinion flange, where there's the strip that's like 1-2 inches wide and runs toward the housing.
I would take a picture but it's too late
_____
/l ,[___],
l--L --[]lllll[]-
()_) ()_)-o-)_)
post #14 of 34 Old 03-31-2013, 07:45 PM
TSEJEEPERS
This is how I have always done it.
http://www.stu-offroad.com/axle/pinion/pinion-1.htm
Quit screwing around with the shims, grind off the spring perches and weld them back up.
Set your pinion angle with the spring perches unwelded and the weight of the Jeep on the axle.
Adjust your pinion angle.
Tack the spring perches in.
Reweld.
93 YJ SOA 2" springs front, XJ springs rear w/main leaf added, High pinon 9 inch rear detroit locker front Dana 44 ARB 4.56 Gears, 36 inch Irok tires too much to list.
TSEJEEPERS is offline
post #15 of 34 Old 03-31-2013, 08:14 PM Thread Starter
1993sahara
Reweld.
thanks for that website, ill have to get one of those angle finders tomorrow. i would go for the cutting and rewelding but as of right now i am out of time to do that.. My jeep is my daily driver and its been out of commission now 3 weeks going on 4 because this 8.8 swap. My d35 blew up 3 weeks ago.
he says about being acouple degrees low if its a yj, i already am acouple degrees low and have vibrations. should i just go the same?
_____
/l ,[___],
l--L --[]lllll[]-
()_) ()_)-o-)_)
