Complete Bushings kit and RE 4" Lift Question - JeepForum.com
post #1 of 11 Old 09-04-2011, 01:42 PM Thread Starter
Bubbagump
Hey everyone, I recently replaced my shocks on my '95 YJ hoping for a softer ride. The shocks help for the large bumps but there's still a lot of bumps that make it uncomfortable. I was curious about a full poly bushings kit. Do they help? Something like this - http://www.jcwhitney.com/total-kit-s...01d1202y1995j4
I also am planning to install a 4" suspension lift. Since I made the mistake of buying new shocks before getting the lift i have to find a lift that doesn't come with shocks. There isn't a large selection but I did find an RE lift that seemed alright. I couldn't find a review on the lift on this website. How do I know if my shocks will work with the lift? http://www.4wheelparts.com/Lift-Kits...R%2fERE5515-NS
Thanks for your help.
Bubbagump is offline
post #2 of 11 Old 09-04-2011, 02:47 PM
LaughingStock
I can't guarantee this is true 100% of the time, but from what I've seen and experienced, a shock that will work on a stock suspension will not have the travel necessary to accommodate what a 4" lift will require. I have seen some aftermarket shocks rated 0-2" or possibly 0-3", but I have yet to see anything made that will go from stock to 4".
I wish I had something more positive to tell you, but based on my experience and research you are going to need to pop for new shocks if you invest in 4" of lift. If you are dead set on keeping the shocks you purchased, you might consider going with a smaller lift in the 2" range. I've heard the offerings from OME, RE and others perform well and allow for larger than stock tires (31" I believe).
I hope this helped some. If not, maybe someone with more knowledge than me can chip in and brighten your day.
LaughingStock is offline
post #3 of 11 Old 09-04-2011, 03:30 PM Thread Starter
Bubbagump
Hmmm well thanks for letting me know before I made the mistake. I guess i could just find a friend to sell em to cheap. They are, after all, on a month or so used. Any advice about the bushings kit?
post #4 of 11 Old 09-04-2011, 03:59 PM
Anticanman
RIP one good jeeper
Anticanman's Avatar
Relocating your shock mounts will help you get away with having a shorter shock on a higher lift and keep them from dragging on rocks as well. As for the Bushing kit, it helps quite a bit considering that your old rubber inserts are old enough to vote. I would opt to get some greasable shackle bolts to compliment. On the topic of finding lift kits without shocks, I always suggest piecing together lifts anyway. Springs can be purchased straight from the manufacturer and in the case of BDS can be shipped to a local distributor for free, saving some coin.
Luck Favours The Prepared
Anticanman is offline
post #5 of 11 Old 09-04-2011, 04:02 PM Thread Starter
Bubbagump
Could I save money by piecing together a lift instead of buying the kit? How do I know what to exactly get and how much do you think I'd save?
post #6 of 11 Old 09-04-2011, 04:17 PM
Anticanman
RIP one good jeeper
Anticanman's Avatar
Let's start here: what are your goals for your jeep? I'll play personal shopper for a minute and then we can move it to PM when people complain about the same threads being posted over and over blah blah blah. I believe I found a 3.5" lift with shocks, SYE and DC driveshaft for another thread for under $900 shipped.
post #7 of 11 Old 09-04-2011, 04:27 PM Thread Starter
Bubbagump
Right now I have a 2" Body lift that I installed. One day (Probably next spring) I am going to get 34"s to replace my 30"s. I thought having roughly 2" of padding after getting 34s would be a good idea. So a 4" lift seemed appropriate. But if you think a 3.5" would do just fine then I'd consider it.
post #8 of 11 Old 09-04-2011, 04:34 PM
Anticanman
RIP one good jeeper
Anticanman's Avatar
Do me a favor really quick and fill out your profile, I'll need gearing info before I can help.
post #9 of 11 Old 09-04-2011, 04:46 PM Thread Starter
Bubbagump
Sure I'll just start PMing you
post #10 of 11 Old 09-04-2011, 04:57 PM
Anticanman
RIP one good jeeper
Anticanman's Avatar
Ok before you can even look at 34" tires, you'll have to address gearing and that dreaded rear axle of yours but I'm fairly certain you can get the lift on first and address the rest when the tires go on. If you plan on wheeling bigger tires, you'll need to drop some weight from your wallet but the lift shouldn't be bad at all. If you're mechanically inclined or have a buddy who is and can weld and has an affinity for the type of cool refreshing beverages that you provide, then you're in luck.
On the BDS website there is a catalog and a place on the home page where you can order by part number. Springs usually range from $100 to $120 and that doesn't include the JF discount. Negotiations can take place through the vendor section of JF but I would suggest having it shipped to your local distributor and ordering through BDS to avoid shipping and tax charges. Shocks are a dime a dozen and as I recently learned, most white can shocks are the same no matter what name is on them. Pro comp rancho Skyjacker, all the same for about $30 apiece. Crown has a SYE kit on eBay that I picked up for $200 shipped so cross that off your list too. Driveshaft and pitman arm can be found at a junkyard from a Cherokee (pull the '95 and newer axle shafts while you're at it!) and the driveshaft can be cut to specific length for under $100 at any reputable driveline/pto manufacturing company. The junkyard parts should be under $50 including the shafts depending on your negotiating skills and rapport with the folks behind the counter and helper monkeys on the forklifts.
Don't forget to source craigslist for parts, there is always someone upgrading from the exact set up you're striving for and it will only benefit you to clean out their garage at a discount price.
post #11 of 11 Old 09-04-2011, 05:02 PM Thread Starter
Bubbagump
Alright thanks for the advice its a big help!
What parts do i need to complete my 2" lift? Please help. larstore TJ Wrangler Technical Forum 14 11-12-2009 04:08 PM
4" Lift, suggestions on what else to complete... robmckim2 Wrangler General Discussion 1 11-11-2008 01:41 AM
TJ Complete Bushings Replacement kentukred TJ Wrangler Technical Forum 4 04-26-2008 11:16 AM
4" lift complete or not complete? Dans1tj TJ Wrangler Technical Forum 8 05-14-2006 09:38 AM
Best 3.5 or 4" lift(Complete) namtrah YJ Wrangler Technical Forum 0 05-01-2003 12:18 PM
