Complete Brake Replacement. Your Thoughts? - JeepForum.com
post #1 of 16 Old 04-03-2013, 06:45 PM Thread Starter
BlackGallagher
I'm about to replace my rear drum brakes on my '89 and I want to know if I should just replace the wheel cylinders, brake boots, and small parts. I was just going to do the drum brake itself, but recently my father had to have all the hardware on his 2005 F-150 replaced because it was rusted and the brake drum would have been no good with the rusted hardware. It's only about $100 investment, but I still want to know what you all think about whether or not I should do it all.
BlackGallagher is offline
post #2 of 16 Old 04-03-2013, 06:56 PM
Anticanman
RIP one good jeeper
Anticanman's Avatar
You could have disk brakes for about $100 more.
Luck Favours The Prepared
Anticanman is offline
post #3 of 16 Old 04-03-2013, 07:14 PM Thread Starter
BlackGallagher
Any recommendations on where to get a conversion kit?
post #4 of 16 Old 04-03-2013, 07:14 PM
mrdeath2000
Ah the good ol $50 job that turns into, well for $50 more I can just do all the hardware... then... well for $100 more I can have discs... well for 200 more i could have an 8.8. well for 300 more i could do an 8.8 and new brakes... etc LOL
93' YJ 2.5L, 4.88's, 8.8, E-Locker & LSD
mrdeath2000 is offline
post #5 of 16 Old 04-03-2013, 07:20 PM
jbolty
jbolty's Avatar
Whenever I do brakes I always replace everything. The parts are so cheap. Wheel cylinders are about $9 and the spring kit is about $15.
Brakes are the only thing on a D35 worth spending money on.
jbolty is offline
post #6 of 16 Old 04-03-2013, 07:43 PM
jokerchief462
Do it all clean the backing plates and reinstall you won't regret it. It would be hell to have a spring break on the trail or a cylinder leak right after you do the brake pads. Paint the drums with some heat paint won't show any rust through your wheels.
89YJ 2.5L TBI, AX-5, NP231 SYE, Ford 8.8, Yukon Grizzly, Tom Woods Shaft, 33" BFG T/As, 4" lift, Warn VR10000s.
AF Jeep Club Tail #184
jokerchief462 is offline
post #7 of 16 Old 04-03-2013, 07:50 PM
GrantYJ
Same here.
“The test of the machine is the satisfaction it gives you. There isn't any other test. If the machine produces tranquility it's right. If it disturbs you it's wrong until either the machine or your mind is changed.” ― Robert M. Pirsig, Zen And The Art Of Motorcycle Maintenance: An Inquiry Into Values
GrantYJ is offline
post #8 of 16 Old 04-03-2013, 08:06 PM Thread Starter
BlackGallagher
Yeah I just ordered all the parts for a complete drum replacement. Disks might be (are) better, but the only conversion kits I saw were for $400+ and I haven't had any problems with the drums thus far so why fix what isn't broke?
post #9 of 16 Old 04-03-2013, 08:07 PM
Anticanman
RIP one good jeeper
Anticanman's Avatar
The conversion I was referencing was a 8.8
post #10 of 16 Old 04-03-2013, 08:11 PM
ROWA
ROWA's Avatar
As mentioned above, replace all part's. Do one side at a time so you have something to compare it to.
94 YJ Sahara
The best Engineering is no match against natural Stupidity.
ROWA is offline
post #11 of 16 Old 04-03-2013, 08:20 PM
USMCBuckWild
I am in the midst of converting my YJ to hydroboost. Got the complete hydroboost, master cylinder, prop valve, brake pedal assembly, p/s pump and lines from a 2008 Silverado 6.0 for $56. I will snap some pics as to how it goes.
I know this is a far reach from upgrading wheel cylinders, but mine started with upgrading the stock prop valve for the 8.8 with discs.......
91 YJ, 350/700R4/231, 8.8/HPD30 with 3.73s, 6" SOA with 38" TSLs. If I ever see the previous owner again, I am going to curb stomp that meth-head brain dead crackpot.
USMCBuckWild is offline
post #12 of 16 Old 04-03-2013, 10:59 PM Thread Starter
BlackGallagher
Well damn! Yeah some pics would be awesome to see!
post #13 of 16 Old 04-03-2013, 11:01 PM Thread Starter
BlackGallagher
Paint the entire drum? With some POR-15 heat resistant coating?
post #14 of 16 Old 04-04-2013, 04:49 AM
Mark05059
being your in pa you should change everything in there including the drums. Dont pain the inside of the drum.. Only the outside.
1998 ZJ 5.2 Auto
1989 Wrangler Black Bone Stock 2.5l 5spd
/l , [____],
|---L--[]lllllll[]-
()_) ()_)==O=)_)
Mark05059 is offline
post #15 of 16 Old 04-04-2013, 09:51 AM
calvynandhobbs
calvynandhobbs's Avatar
I picked up the front and rear axles out of a 96 Grand Cherokee for $130 for the pair. The rear is a D35 with discs so I'm converting that over to the S35 I have sitting in the back of the garage before I put it under the YJ. The kits are overly priced, but if you have time just watch Craigslist and junkyards for part outs. I got lucky in that mine has brand new rotors and pads on it. The guy had just replaced them and the tranny went 3 weeks later so he parted it out. The front axle will be stripped of wheelbearings, axleshafts, etc for spares.
94 YJ - work in progress
calvynandhobbs is offline
