Cold Weather Starting Issues - JeepForum.com
post #1 of 7 Old 10-12-2009, 10:39 PM Thread Starter
premierwheelman
I just moved to an area where there are much colder temperatures than I am used to, and since the temperature around here has dropped to around 20 degrees fahrenheit, my jeep has been struggling to start. My battery, and starter are both good so I was wondering if anyone has had similar issues and might know of a fix to my problem?
premierwheelman is offline
post #2 of 7 Old 10-12-2009, 10:55 PM
MJMPC
What do you mean hard to start ? hard to crank, takes a lot of cranking to start ??
MIKE
MJM Powder Coating
Elizabethtown Ky.
MJMPC is offline
post #3 of 7 Old 10-12-2009, 11:17 PM Thread Starter
premierwheelman
It is slow to start, crankes like it has an almost dead battery, but the battery has a full charge. So it turns over slower and more times than it usually takes.
post #4 of 7 Old 10-12-2009, 11:22 PM
MJMPC
Bat might be to small takes a stronger bat to start in cold weather. And I know this sounds stupid but change your oil .
MIKE
MJM Powder Coating
Elizabethtown Ky.
MJMPC is offline
post #5 of 7 Old 10-12-2009, 11:56 PM Thread Starter
premierwheelman
I just put in a new Everstart Maxx today its 900amp with 770 cold cranking amps, which is about 200 more cca than what was reccomended by the manufacturer. For Oil I am running 10w30 fully synthetic mobile 1, its been a while since my last oil change, but my jeep has trouble even when it is warmed up so i do not think the viscosity of the oil is the issue.
keep throwing things out there and ill keep checkin!
Thanks
post #6 of 7 Old 10-13-2009, 12:16 AM
SnowdogMarc
Take it from someone who lives in the snow belt. We use 5w30 all year and have block heaters in our vehicles. With the block heater it cranks over like it's a summer day even when it's -30
Also check all your ground and battery connections and cables, one of them may be getting bad.
l We're here for a good time. Not a long time. So have a good time the sun can't shine every day.
l_______
/l ,[_____],
l---L -[]lllllll[]-
()_) ()_)--o-)_)____________VE6-SDG
SnowdogMarc is offline
post #7 of 7 Old 10-13-2009, 12:35 AM
MJMPC
Ok check and clean all the grounds. If that dont help the only thing I can think of is the starter, maybe you can have the starting system checked to see how many amps the starter is drawing .
MIKE
MJM Powder Coating
Elizabethtown Ky.
MJMPC is offline
Cold weather starting problem. Deadhorse TJ Wrangler Technical Forum 1 02-17-2009 06:43 AM
2 Issues--cold weather starting white sox bill YJ Wrangler Technical Forum 3 12-02-2008 09:12 PM
Delayed starting in cold weather! Help! Tkahne88 TJ Wrangler Technical Forum 6 11-22-2008 12:33 PM
Difficult cold weather starting sreno YJ Wrangler Technical Forum 3 08-13-2007 10:12 AM
starting in cold weather... PistolJeep YJ Wrangler Technical Forum 3 10-25-2006 08:30 AM
