Cold weather Preparation - JeepForum.com
post #1 of 16 Old 09-08-2011, 09:39 PM Thread Starter
VirginJeeper
What do you guys do to prep your jeep for the cold weather? What fluids are you changing? Diffs clutch etc? I'm basically stock with a 2.5L
VirginJeeper is offline
post #2 of 16 Old 09-08-2011, 10:03 PM
oldtime_ironman
I've never had to change much of anything. I use 10W30 oil year-round, its a good compromise. I do try to make sure all the fluids are topped up, and especially the cooling system is up to the job. Summertime we get 98 degrees and muggy, winter can go to -20 and snow up to your butt around here.
I just keep on doing everything on schedule like normal.
oldtime_ironman is offline
post #3 of 16 Old 09-08-2011, 10:21 PM
oldtime_ironman
One other thing, make DARN sure you have a good strong battery, and all the electrical connections are clean and tight.
post #4 of 16 Old 09-13-2011, 09:16 PM Thread Starter
VirginJeeper
transfer case or clutch fluid
sorry a couple of follow up questions, what about fluids? do you run different oil? How about the clutch and transfer case I have meaning to flush both but not sure if a different weight should be used besides the recommended 10w-30?
Thanks
post #5 of 16 Old 09-13-2011, 09:33 PM
oldtime_ironman
Thanks
Just the regular stuff is fine for me.
post #6 of 16 Old 09-13-2011, 09:39 PM
ejeeperguy
1982 CJ7
check the clutch fluid if it is completely clear (no black stuff floating might mean you have a problem) leave it alone.If it is a little low just add some more.
The transfer case; flush it out, use the royal purple.You don't have to change it like engine oil. Every 30000 miles,so using the good stuff is worth the the money. .How many actually do that and don't have any problems.Not me of course; I just finished flushing all mine.I did have to replace the whole clutch system on the wife's 90 yj.
if your going to flush things how about your tranny too. do it the same time as the tcase.then they are always due the same time, 30000 miles.
ejeeperguy is offline
post #7 of 16 Old 09-16-2011, 01:36 PM Thread Starter
VirginJeeper
Thanks for all the suggestions. I'll be flushing the fluids next weekend with royal purple as I've used them and they have always performed well for me.
post #8 of 16 Old 09-16-2011, 02:18 PM
jeepyj13
Check antifreeze in radiator cause if theres none a frozen block can occur. Make sure heater core flushed for the heater to work top notch. If you live in area where snow comes always a great time to make sure 4wd works for that time.
"Its a Jeeps World, other 4x4s just get stuck in it."
jeepyj13 is offline
post #9 of 16 Old 09-16-2011, 03:56 PM
jsawduste
2006 YJ Wrangler
Park it in the garage before the road salt starts. Then bring it out when the salt is gone.
Takes all of a minute or so.
jsawduste is offline
post #10 of 16 Old 09-16-2011, 05:08 PM
Hghgrad
^ that's what I think I'll be doing . Unless of course I absolutely have to drive it.
1994 Wrangler...4.0 AW4 swapped, sye'd, 5.5" lift and 33's
Hghgrad is offline
post #11 of 16 Old 09-16-2011, 05:13 PM
RobsCrawlin7
no balls
RobsCrawlin7's Avatar
that or pressure wash the crap out of the undercarriage every few days
'01 TJ 4.7/NV3550, 2" lift, 35's, locked.
'79 CJ7 stock, 304
'98 XJ sold
'79 CJ7 sold
'82 CJ7 parted
'89 MJ sold
SSG David Mejias, SSG Eric Vick, SGT William Bowling, SGT Robert McDowell
1 April 2007
Rest In Peace Brothers
RobsCrawlin7 is offline
post #12 of 16 Old 09-16-2011, 05:59 PM
giggityjeeper
meh up to you, I get 8 months of snow/-20 to -55 temps, I do nothing aside from plugging it in when it get s below -30, only thing I do is plug it in around NOV to make srue the heater is working and make sure the antifreexe is good so I dont get a block of ice.... OH OH change your washer fluid, lots of people forget that and end up with a busted washer fluid tank when it frezzes to...
SAD, its a jeep not a ferrari, lamest thing I ever heard... really this is just lame
this to, if you live where thye use salt, ..... spay it down good....
Started with some rust repairs ended in a SOA...
family roll bar swap/upgrade..
1990 YJ. SOA, OME 36R 3.5" lift springs, OME 5/8 greasable shackles, OTT high steer, Custom cage, team Rush, Posi, 33 TSL swampers
giggityjeeper is offline
post #13 of 16 Old 09-16-2011, 07:37 PM
oldtime_ironman
Given that you live in Arlington, Va I really think you're reading way too much into it and worrying too much. Put it this way: I live just north of Buffalo NY, just a hair away from Canada, and I don't even worry about it that much. I use synthetic Mobil-1 10W30 year round, no probs. I do let it warm up longer in the winter... start it up and let it idle in the drive until the snow melts off it. The trans and diff fluid stays the same, no changes there. I do check the antifreeze in October, just to make sure its strong enough. It usually lasts a few years without probs. I already had the block and heater flushed last January. You can get the adapter kit to do it at Wal-Mart for $4.
Up here they cure the road kill with salt so it doesn't even start to rot until June. The flies won't even touch it. So I hose it off once a month during winter at the car wash.
And that's all the winter care it needs. Of course I make sure to keep it tuned up and the electricals tight, year round.
post #14 of 16 Old 09-16-2011, 07:49 PM
RobsCrawlin7
no balls
i agree with oldtime, i was stationed up in ft drum and i didnt do anything special there either other than make sure i had a few mre's and water with me. the cold down here in va compared to there is like night and day
'79 CJ7 stock, 304
'98 XJ sold
'79 CJ7 sold
'82 CJ7 parted
'89 MJ sold
1 April 2007
post #15 of 16 Old 09-17-2011, 08:52 AM
raynmaker
http://www.jeepforum.com/forum/f12/y...j-when-502691/
first post. lol
Besides that, anti freeze and a good battery Manual says change from 10w30 to 5w30 but that shouldnt matter unless it cranks slow
Warning: This poster has infinite knowledge of useless information and redneck tendencies. Use info at your own discretion. :wave:
raynmaker is offline
cold weather rvd502002 JK Wrangler Technical Forum 11 01-23-2011 06:39 PM
Cold Start New to Cold Weather Thexonexkid TJ Wrangler Technical Forum 18 12-02-2009 01:39 PM
Cold Weather and MPG fraynes1 JK Wrangler Technical Forum 10 01-15-2007 07:09 AM
Cold Weather and 4 WD jnorton1 YJ Wrangler Technical Forum 8 12-06-2005 08:38 PM
hot to cold weather classicjeepman YJ Wrangler Technical Forum 1 01-21-2002 06:33 PM
