Cold Starting Check Engine light - JeepForum.com
post #1 of 1 Old 02-23-2008, 07:37 PM Thread Starter
woody59
I looked through a lot of the threads and think I have this nailed down but wanted to make sure. I have a '93 4 cylinder that is normally really faithful, even in cold weather. This Ohio winter has been rough and now I have to wait for the check engine light to turn on before starting. Once it comes on (sometimes over 5 min) it starts right up. Also, not sure if this is related but my gas mileage went south as well.
I checked all the spark plugs and everything looked good.
New fuel filter but no help.
Was thinking it might be the CPU??
Well, after doing more research, I'm going to try replacing the capacitors in the PCM. Hopefully this takes care of it.
http://www.jeepforum.com/forum/f13/fixing-lazy-pcm-new-caps-writeup-501951/
woody59 is offline
Cold Engine Starting Trouble sherrodk YJ Wrangler Technical Forum 15 10-21-2009 10:24 AM
starting trouble; now check engine light (need help) dabrogger TJ Wrangler Technical Forum 1 02-06-2009 01:31 AM
Check Engine Light and cold weather?? Mickeymouse YJ Wrangler Technical Forum 15 01-04-2009 02:52 PM
Check Eng light on after Cold airitnake install sfr119 TJ Wrangler Technical Forum 8 09-17-2008 07:03 AM
95 YJ 2.5L - Check Engine Light on when starting cold gary1 YJ Wrangler Technical Forum 7 02-03-2006 07:10 PM
