Cold start questions - JeepForum.com
post #1 of 7 Old 11-13-2013, 09:15 AM Thread Starter
Chase0808
I have a 88 yj with a MC2150. It's runs great most of the time but now that it's starting to get cold out it runs a little rough. It's starts good in the morning but in the afternoon around 7ish, it has some issues. It will turn over but has trouble starting. Once it does start, it usually stalls even with me keeping my foot on the gas to get the rpms up. After a couple try's it'll eventually start up and I'll let it warm up for about 10 minutes. After that it'll still stall if I come to a complete stop for a couple seconds. If I need to, I just shift to neutral and keep the rpms up until the light is green. Any suggestions on cold starting or warming it up?
Sent from my YJ
Chase0808 is offline
post #2 of 7 Old 11-13-2013, 10:14 AM
superj
your choke sounds to not be working or adjusted properly. i would start there.
I don't feel like working on anything at this time so i sold my yj.
superj is offline
post #3 of 7 Old 11-13-2013, 08:04 PM Thread Starter
Chase0808
Okay I'll check it. When I tried to start it up today it would not fire up for a while. Mate 10 minutes. I hear what sounds to be grinding of gears. The starter is only a couple months old so I'm guessing it's the flywheel. It's getting worse and worse and I'm leaning towards the flywheel. Anybody know if this is it? I also heard that the flywheel is a pita to replace. Is this true?
Sent from my YJ
post #4 of 7 Old 11-13-2013, 08:06 PM Thread Starter
Chase0808
Originally Posted by Chase0808
Okay I'll check it. When I tried to start it up today it would not fire up for a while. Maybe 10 minutes. I hear what sounds to be grinding of gears. The starter is only a couple months old so I'm guessing it's the flywheel. It's getting worse and worse and I'm leaning towards the flywheel. Anybody know if this is it? I also heard that the flywheel is a pita to replace. Is this true? Sent from my YJ
Sent from my YJ
post #5 of 7 Old 11-13-2013, 08:55 PM
Old4X
1990 CJ7
Pull the starter and turn the engine by hand. Inspect ring gear teeth on flywheel for damage. If damage is found, you need to replace the ring gear and starter bendix, standard maintenance work.
On your carb, get the workshop manual for that carb and set the auto choke to spec.
418 miles on 19 gallons of gas. Can't beat the BBD !
Old4X is offline
post #6 of 7 Old 11-14-2013, 05:27 AM Thread Starter
Chase0808
Okay. If the flywheel needs replacing, is it a pain to do?
Sent from my YJ
post #7 of 7 Old 11-14-2013, 06:04 AM
Que89YJ
Que89YJ is offline
