Cold start issue even during warm weather - JeepForum.com
post #1 of 7 Old 05-17-2010, 02:35 PM Thread Starter
Cards89YJ
My YJ has been Nuttered. I am not sure the timing on the Jeep right now. I haven't checked it out. The nutter was done by previous owner. This symptom seems to come and go, but has gotten worse lately. When I start the Jeep after a couple or more hours of being turned off it idles very roughly to the point of dying or almost dying out before the choke will kick in properly. It shakes and stutters up until that point. If I try to press the gas pedal while it is doing this, it will spit and sputter and die. Once the choke kicks in the Jeep warms up and runs fine. No issues at that point.
What would cause this? Is there a simple solution?
Cards89YJ is offline
post #2 of 7 Old 05-17-2010, 02:45 PM
dtn8tr
What carb do you have installed?
1997 TJ, 5" IRO front with 4.5" HD IRO WJ rear, 35x12.5x15 Mickey Thompson MTZ, JKS disconnects
dtn8tr is offline
post #3 of 7 Old 05-17-2010, 02:46 PM Thread Starter
Cards89YJ
It still has the original Carter carb
post #4 of 7 Old 05-17-2010, 03:05 PM
bl907
My YJ had the hardest time starting as well. I ended up doing a rebuild kit in my carter, and re-timed it. Got rid of all the unnecessary vacuum lines and smog garbage. Many people here will tell you to junk the carter, or make a paper weight out of it, and get a motorcraft or any other carb. Carters are not the best, but since I rebuilt mine six months ago there have been no clogged idler tubes, flooding out, or hard starting. For 15-20 bucks it is worth a shot.
bl907 is offline
post #5 of 7 Old 05-17-2010, 03:14 PM
dtn8tr
What is the idle at when it does run correctly? If it is too high it is actually bypassing the idle circuit IIRC. Truthfully, I would ditch the Carter but there are a few ppl on here that know quite a bit about fixing them. Mine started going out and I just found a Weber. Took all of about two hours to install and adjust and I don't regret it the least.
dtn8tr is offline
post #6 of 7 Old 05-17-2010, 03:15 PM Thread Starter
Cards89YJ
It idles between 600-800
post #7 of 7 Old 05-17-2010, 03:56 PM
dtn8tr
As BL907 said the cheapest fix would be a re-build...might be a float that is sticking occasionally. If you're comfortable with it, get a kit and strip it down and clean it really well. It's worth a try. I found my Weber on Craigslist for $125 with the Jeep conversion adapter.
dtn8tr is offline
91 won't start in cold weather? medtech YJ Wrangler Technical Forum 7 11-16-2016 04:18 PM
Cold Weather Start - Grinding ten27oh4 JK Wrangler Technical Forum 19 01-04-2011 02:52 PM
YJ won't start in cold weather dimjeep YJ Wrangler Technical Forum 2 02-27-2010 11:01 AM
Cold Start New to Cold Weather Thexonexkid TJ Wrangler Technical Forum 18 12-02-2009 12:39 PM
rough idle on hot start - only in warm weather willwheel4food TJ Wrangler Technical Forum 1 03-17-2006 10:12 PM
