Cold=Runs Like Crap, Warm=Runs Good - Help! - JeepForum.com
post #1 of 10 Old 11-21-2008, 07:43 AM Thread Starter
CheapSunglasses
2007 XK Commander
I rebuilt my crapola Carter and reinstalled on my 4.2 when the weather was in the 60' and she ran fine.
Now that the weather dips into the 30's at night and barely into the 40's during the day, she runs HORRIBLE until warmed up.
Symtoms are: At startup she sputters so bad I have to feather the gas for 30 seconds until she clears out and runs fairly steady....I start to drive and come to the end of my street and she races to about 1500 RPMs....I then drive for a half a mile or so and she starts to studder and miss, so I downshift to get the RPMs up and she kinda clears out....I drive a little wile longer and come ot a stop sign, she races to about 1100 RPMs and then slowly drops until she stalls....I start her back up and drive to my destination and she races at about 1500 RPMs until I pull into the parking spot and then I shut her off to a slight run on and finally off....This is most embarassing because I drop my daughter off at school every morning and all the hot little soccer moms in their Lexus' and Benz's point and snicker at me
She finally starts running okay when I pull back into my driveway
I have NO CLUE what the issues might be and am not in the position now to nutter or change to a different carb or FI....I would just like some possible tips on how th get my mojo back
"The Bannana Channell, Programming With Appeal"....Stay Tuned For a Bunch More!
CheapSunglasses is offline
post #2 of 10 Old 11-21-2008, 08:09 AM
kmj153
My jeep does the same thing (1990 with carter carb). I just let it get warmed up and then I drive it.
1990 YJ, Waggy 44's, 4.56, ARB's, 35's, 4.2 w/ Howell FI, Stak Dana 300 RAC, w/ JB 4:1 and 32 spline output, undercoverfab belly up
2005 F-150, DD/Tow rig
kmj153 is offline
post #3 of 10 Old 11-21-2008, 08:15 AM
Brown Dog
Vendor
Brown Dog's Avatar
It has to be an automatic choke issue. Is the bi-metal coil that operates the chole properly engaged?
Brown Dog Offroad
Motor Mounts, Motor Mount Lifts (MML), and Engine Brackets for Jeep
100% HANDCRAFTED IN AMERICA
91YJ 2.5
Brown Dog Mounts and Engine Brackets (Serial Number 1)
2" BL
4.5" Superlift SL
AA SYE
35" GoodYear Mud Terrains
Conteract Balancing Beads
Bulldog front bumper
Best Top seats
"Family" roll bar
25 foot 1/2" log chain
No Top, No Doors (Best Top Safari)
Brown Dog is offline
post #4 of 10 Old 11-21-2008, 12:00 PM Thread Starter
CheapSunglasses
2007 XK Commander
How do I tell?....It moves freely by hand, but I'm not sure if it is acting properly during warm-up.
post #5 of 10 Old 11-21-2008, 12:07 PM
ritjobbie
I second the choke diagnosis, but it could be a thermostat problem If the thermostat is stuck open, the engine will take forever to warm up. This happened on my 1986 Toyota 22R engine. Ran like crap for more than 20 minutes and never warmed up in the winter.
1995 YJ Rio Grande, 2.5L Low Output Engine
ritjobbie is offline
post #6 of 10 Old 11-21-2008, 12:16 PM
jbolty
jbolty's Avatar
Check the manifold heater too.
jbolty is offline
post #7 of 10 Old 11-21-2008, 06:44 PM Thread Starter
CheapSunglasses
2007 XK Commander
I bought a new thermostat a couple of weeks ago and have'nt had a chance to install it....I'm gonna do it this weekend.
I'm also gonna check the manifold heater and choke as suggested (thanks)....Any other ideas?
post #8 of 10 Old 11-22-2008, 07:36 PM
jay-h
this is not normal It should work well cold.
With the engine dead cold in the morning, remove the air cleaner look to see that the choke valve is (lightly) closed. when the engine warms up it should be fully open.
Be sure the hot air duct hose is in place from the exhause manifold up to the air cleaner. Make sure the flapper valve on the air intake snorkel moves when the engine starts cold to draw air through the hot air duct.
There are two important sensors, one on the air cleaner houseing, one by the intake manifold (see the sprynet link in the faq to find thes). Be sure they are both working as they should.
jay-h is offline
post #9 of 10 Old 11-22-2008, 07:48 PM Thread Starter
CheapSunglasses
2007 XK Commander
That could be another issue....I don't have the tube from the manifold to the air cleaner. Thanks!
post #10 of 10 Old 11-24-2008, 10:56 PM
lclark2074
can anyone tell me ware the elect for the choke is fed forum? my choke is not getting no power to heat up element it is a 4.2L with a carb
lclark2074 is offline
95 4.0 runs horrible when warm freemason YJ Wrangler Technical Forum 23 08-05-2009 01:29 AM
06 TJ runs bad when warm TL88427 TJ Wrangler Technical Forum 10 06-21-2008 12:33 PM
4.0 runs like crap when it gets warm tbenne6 YJ Wrangler Technical Forum 2 01-30-2008 11:12 AM
Help! 2.5L runs like crap, HELP! Big-n-Broke-YJ YJ Wrangler Technical Forum 54 10-20-2006 06:53 PM
91 YJ Runs fine when cold, misses when warm c21no1 YJ Wrangler Technical Forum 1 04-17-2005 10:50 AM
