Cold Engine Starting Trouble - JeepForum.com
post #1 of 16 Old 10-06-2009, 07:05 PM Thread Starter
sherrodk
2 months ago I purchased a 1994 Jeep Wrangler YJ, It has been running great but this week it started taking 3 to 4 minutes of cranking in the morning to get it started. After that it starts great unless it is off for 4 to 5 hours then same thing. I have replaced the fuel filter, and plugs but do not know what to try now. Any help would be great
sherrodk is offline
post #2 of 16 Old 10-06-2009, 07:12 PM
Mean Max
Don't poke the bear
Mean Max's Avatar
Read this thread & see if it applies to your situation.
http://www.jeepforum.com/forum/f12/c...rs-ecu-492597/
Max
Originally Posted by UltimatE View Post
Max has a picture of every Jeep part ever made.
Originally Posted by Benderff View Post
No one here knows what they are talking about. You should try Pirate 4x4 they will be happy to help you.
There is no situation that cannot be improved with a small but well-placed explosive.
Mean Max is offline
post #3 of 16 Old 10-06-2009, 07:32 PM Thread Starter
sherrodk
I have not seen a problem with the check engine light or hearing a clicking sound when I turn the key on. It does crank every time. I forgot to say once it does start it almost sounds like it is flooded and takes about 30 seconds then goes to a high idle.
sherrodk is offline
post #4 of 16 Old 10-07-2009, 06:25 PM Thread Starter
sherrodk
This may help, today was the first day I have started my jeep in 3 days. I turned the key to on then waited for the Check Engine light to come on. Once it did it started right up.
sherrodk is offline
post #5 of 16 Old 10-07-2009, 07:19 PM
brinoff
brinoff's Avatar
What code does the check engine light give you? My guess is a sensor; crank position, throttle postion, or oxygen.
93YJ 4.0 I6, AX-15, NP231 Teraflex SYE, Tom Wood Drive Shaft, G2 D44 ARB, ARB locked 30, T&T customs axle trusses, ProComp 35" Mud Terrain, RE SD 4" Lift, Daystar 1" BL, Harbor Freight 8000 Winch, Swing Away Tire Carrier, and some other stuff.
brinoff is offline
post #6 of 16 Old 10-10-2009, 10:03 AM
Georgec3_
2010 JK Wrangler
My temp gauge isn't working in my YJ. I bought a cheap temp sending unit at the salvage. When I put it in the motor would hardly stay running, and my temp gauge still didn't work. I put the old one back in and it runs just fine. The short version try replacing the temp sending unit
Georgec3_ is offline
post #7 of 16 Old 10-10-2009, 03:04 PM
idaholtby
If that is the case, then I suggest you reread the link that MeanMAx provided. Bad capacitors in the ECU are the cause of the CEL light not coming on immediately when the ignition is turned on. This means the ECM is not powered up initially, therefore no power to the ASD or Fuel pump until the CEL lamp illuminates, thus the hard starts when cold.
idaholtby is offline
post #8 of 16 Old 10-13-2009, 09:03 PM Thread Starter
sherrodk
I checked the codes and Got 12 - 33 -55. Looking at the list I do not see it listing a problem. Do you think it may by the Fuel pump relay control circuit?
sherrodk is offline
post #9 of 16 Old 10-13-2009, 09:46 PM
MJMPC
Have you checked the fuel pressure at the rail ?
MIKE
MJM Powder Coating
Elizabethtown Ky.
MJMPC is offline
post #10 of 16 Old 10-15-2009, 07:32 PM Thread Starter
sherrodk
Ok I am pretty sure its the ECU, I am going to give it a try this weekend.
sherrodk is offline
post #11 of 16 Old 10-18-2009, 05:57 AM Thread Starter
sherrodk
Ok gave it a try Saturday and the capacitor on the right by itself was blown, and keeps blowing repaced that one twice. Now the jeep won't start at all, the check engine light never comes on. What do you think the next step should be?
sherrodk is offline
post #12 of 16 Old 10-18-2009, 08:17 AM
idaholtby
Did you install the capacitors with the strip on them in the same orientation as the ones you removed? They are electrolytic, so they have to be installed with the correct polarity. The strip indicates which side is the negative. If the new cap is "blowing", it sounds like it may be installed backwards. The ECM is definitely at fault here and these capacitors have always been the fix. If you can't get these to work, then you will need another ECM.
post #13 of 16 Old 10-18-2009, 08:44 AM
YJ Newby
Max
Probably a dumb question, but will this fix work on a 4.2L that has been "nuttered"? My Jeep cranks and cranks and cranks in the morning, but once the engine is warm, it fires up beautifully. Or, should I be looking at something else as the root of my cold starts?
Thanks!
YJ Newby is offline
post #14 of 16 Old 10-18-2009, 09:41 AM
idaholtby
Thanks!
No, it is only for '91-'95 OBDI 2.5L and 4.0L
post #15 of 16 Old 10-21-2009, 10:17 AM Thread Starter
sherrodk
If I did install them incorrectly would that hurt it? I will check and see if they are in correctly and re-do them.
sherrodk is offline
starting trouble; now check engine light (need help) dabrogger TJ Wrangler Technical Forum 1 02-06-2009 01:31 AM
Engine had some trouble starting up this morn. faxmachine YJ Wrangler Technical Forum 3 12-01-2008 01:56 PM
Trouble starting / Hard Start (not a cold weather problem) itsajeepthang86 YJ Wrangler Technical Forum 0 11-06-2008 12:46 PM
Engine starting trouble bunkrdfool YJ Wrangler Technical Forum 7 06-24-2008 04:09 PM
Cold Starting Check Engine light woody59 YJ Wrangler Technical Forum 0 02-23-2008 07:37 PM
