Cold blooded yj!!! - JeepForum.com
post #1 of 13 Old 11-07-2013, 06:55 PM Thread Starter
758879
1987 YJ Wrangler
Cold blooded yj!!!
hey, so my yj that i recently acquired in june has been running like sh*t! it has the 4.2 and i did the nutter reset the timing cleaned the carter carbeurater( has a manual choke) checked for vacuum line leaks and for some reason it runs like terrible when its cold, it will die wont idle and if it does its really rough. The funny thing is when its warmed up it idles super smooth and runs great! Is there anything i can do to make it not such a b*tch to start my thought was to put a motorcraft on but after doing research the carb seems so hit or miss and an expensive risk. someone suggested putting an hei distribueter on and maybe that would help. Im so lost on it so please help!
I would support obama care if it covered my jeep too!
758879 is offline
post #2 of 13 Old 11-07-2013, 07:09 PM
dancytron
Do the things that are on it stock to make it run better in the cold work, i.e. the manifold heater and the tube from air cleaner to the exhaust manifold with the flap door?
FWIW, mine is almost totally stock except nutter bypass and team rush and it starts and runs dependably no matter how cold it is. Figure out what is wrong with it, don't throw expensive parts at it.
I have a manual choke. It does take a lot longer to push the choke in the colder it gets.
dancytron is online now
post #3 of 13 Old 11-07-2013, 09:12 PM
Sparrows
Not to hijack, but...
Mine has been acting up in the cold too. Similar issue; barely idles when I first start it, "lopes" really bad, and I have to give it a little gas/rpm to keep it going for the first few seconds. After about 30 seconds of idling, the rpms jump a bit, and it sounds fine. Once it has idled a minute it runs fine like normal. If I try to start it and just drive off, it tries to stall out, especially between gears. Any thoughts?
Jeep 2.5L/Ax5.
Cheers
June '13 YJOTM
Sparrows is offline
post #4 of 13 Old 11-08-2013, 07:22 AM
Old4X
1990 CJ7
Lose the manual choke and put the auto choke back on.
Make sure the heat stove, CTO, and vacuum system is properly connected and working. Check the entire motor and vacuum system for leaks, esp the EGR system and the intake manifold to head gasket area. Also check the carb baseplate for vacuum leaks.
Poor cold engine operation is always a lean mixture problem, find out why it is running lean.
418 miles on 19 gallons of gas. Can't beat the BBD !
Old4X is offline
post #5 of 13 Old 11-08-2013, 07:55 AM
Siva283
Jeep 2.5L/Ax5.
Cheers
Your MPFI like me. These guys ae carbs. Big Big difference. If I were you I would start with checking for codes.
Ask me how I know...
Siva283 is offline
post #6 of 13 Old 11-08-2013, 12:18 PM
Sparrows
No codes. Just a similar problem and I know its a big difference, just figured there was no reason to start a new thread.
Cheers
June '13 YJOTM
Sparrows is offline
post #7 of 13 Old 11-08-2013, 12:59 PM
Siva283
Cheers
Have you checked for Vac leaks? I am trying to remember what Que taught me when he was helping me with an issue. When the engine is cold the air temp, coolant temp, and map sensor are what controls the air\fuel mix. I would check for vac leaks and then check those sensors to make sure they are clean. How does it run at WOT. It will again switch back to those sensors at WOT.
Siva283 is offline
post #8 of 13 Old 11-08-2013, 01:20 PM
Sparrows
Haven't checked for Vac leaks yet. At WOT it runs fine. So I start it and it "stumbles" for about 30 seconds at what seems to be too low of an idle, after about 30-45 seconds, the rpms jump a bit and it idles fine. If I start it and mash the gas to WOT, it runs fine while the gas is on, but when it returns to idle it begins stumbling again until it's ran for a bit...
Cheers
June '13 YJOTM
Sparrows is offline
post #9 of 13 Old 11-08-2013, 01:25 PM
Siva283
Have you checked fuel pressure? Particularly if the pressure stays above 20psi for 20 minutes with the engine off.
Siva283 is offline
post #10 of 13 Old 11-08-2013, 02:20 PM
Sparrows
I must admit, I don't know how to check that.
Cheers
June '13 YJOTM
Sparrows is offline
post #11 of 13 Old 11-08-2013, 02:49 PM
Siva283
Cheers
You cant rent the gauge from autozone or advance. It hooks up to the Schrader valve on the fuel rail(looks like a valve stem from a tire) Start up the engine. You should be reading 31 psi. Pull the vac line of the Fuel Pressure regulater(other end of fuel rail) it should shoot up to 39 psi. Shut the engine off leave the gauge hooked up. It should stay above 20 psi for 20 minutes.
Siva283 is offline
post #12 of 13 Old 11-08-2013, 03:15 PM
Sparrows
Thanks.
I'll try that tomorrow.
Cheers
June '13 YJOTM
Sparrows is offline
post #13 of 13 Old 11-08-2013, 03:46 PM
Old4X
1990 CJ7
None of the fuel pressure,sensor, fuel regulator, fuel rail, schrader valve, leakdown test, etc drivel has ANYTHING to do with the OP's problem.
If you want to troubleshoot fuel injection woes, please start your own thread. You are doing nothing but confusing newbies to the site here.
Old4X is offline
