coiol conversion - JeepForum.com
post #1 of 5 Old 07-10-2001, 12:51 AM Thread Starter
batha
coiol conversion
Anyone out there ever bolted on the Explorer coil conversion for a YJ? Had my leafs custom bent to about a 4" lift but it rides like hell and starting to sag. Just wondering if the coils are worth it for the ride or if it is just a TJ envy thing.
Thanks in advance.
Dano
batha is offline
post #2 of 5 Old 07-10-2001, 02:53 AM
bigjeep39
bigjeep39's Avatar
Dont do it!
1998 TJ
Slow steady project.
bigjeep39 is offline
post #3 of 5 Old 07-10-2001, 11:18 AM
rayray
rayray's Avatar
Over rated.
Earth First! We can wheel the other planets later
rayray
rayray is offline
post #4 of 5 Old 07-10-2001, 11:21 AM
JPFREEK
JPFREEK's Avatar
REAL JEEPS HAVE LEAF SPRINGS
-Pete
'91 YJ
JPFREEK is offline
post #5 of 5 Old 07-10-2001, 08:29 PM
NaeKid
JF Administrator, eh?
NaeKid's Avatar
There are many kits that you can install that have the leaves arched just enough to fit the tires you wish.
The coolest right now is the 6" monoleaf kit .. a little expensive, but the ride is amazing!
I have the 4" SuperLift kit on mine .. a little stiff, but it probably will not sag out over time.
A friend has installed the 4" Rancho kit, and his springs sagged out so bad, that its like a 1" lift now .. he has a 3" body lift, so he can still clear his 33" tires.
Hello, my name is Vance and I am a Jeepaholic.
Its better to be naked with your friends, than to be clothed with your enemies
Silver
, zombie ready as the daily-driver
NaeKid is offline
BA-10 to AX-15 conversion benjeep90 YJ Wrangler Technical Forum 2 07-20-2008 03:42 PM
4.0 conversion ECM HELP mpower23 YJ Wrangler Technical Forum 1 12-16-2007 09:20 AM
tj to zj tie rod conversion yellowismellow TJ Wrangler Technical Forum 3 11-28-2006 12:02 PM
SOA Conversion for $75 AHighFiveToLife YJ Wrangler Technical Forum 10 01-09-2006 06:43 PM
SOA conversion ?'s BlackWhyJay YJ Wrangler Technical Forum 21 12-12-2003 05:13 PM
