Coil suspension conversion on '90 YJ- should I?? - JeepForum.com
post #1 of 30 Old 06-19-2012, 08:19 PM Thread Starter
rage4order
2015 JK Wrangler
I have owned my 90 YJ for almost 20 years now and I just love it. I have 32" tires and a 3.5" suspension lift on it. So, here's my predicament. I have been really thinking about buying a newer model Jeep, probably a 4dr Unlimited and the main reason is the ride. I'm 40+ years old and my 90 rig just is too rough and bouncy on regular road driving. BUT, if I could do a coil suspension conversion, I would gladly hang onto it! My questions are, is a coil conversion kit a good way to go? Would it improve my street ride? Has anyone installed one and if so, how do they like it?
rage4order is offline
post #2 of 30 Old 06-20-2012, 08:48 AM
crackedcornish
what brand leaves do you have on it now? Some springs are flexier than others, and a good set of flexy springs will ride nicer on the pavement than some of the stiffer ones
I wheel a YJ 'cuz it's relatively cheap and easy to fix, but if you can afford to wheel a newer Unlimited....I say go for it
Orange Jeep Club #88
˙ɹǝʌo ɹǝʇndɯoɔ ɹnoʎ dılɟ sıɥʇ pɐǝɹ uɐɔ noʎ ɟı
crackedcornish is offline
post #3 of 30 Old 06-20-2012, 10:10 AM
scubamc
Going with a coil or coilover suspension will ride better than a leaf suspension. I am running the Polyperformance 3 link kit in the front with coilovers. Genright also has some really nice "kits".
Horsepower is like a hot girl with STDs. You know you want to hit it but you're afraid of the consequences.
scubamc is offline
post #4 of 30 Old 06-20-2012, 10:13 AM
1988jeepyj
Search comments for the coil spring conversion kits, super expensive and people say theyre horrible. I was looking that route for my 1988 but the kits are like $1600 and people have really not recommended them
1988 YJ 2.5, again!
1988jeepyj is offline
post #5 of 30 Old 06-20-2012, 10:29 AM
crackedcornish
if you want to keep you YJ look but move to coils, there is a Hybrid frame available that is set up to use any TJ suspension, stock or aftermarket, under a YJ tub/drivetrain
http://www.throttledownkustoms.com/framesHybrid.html
post #6 of 30 Old 06-20-2012, 10:38 AM
1988jeepyj
That is cool...
1988 YJ 2.5, again!
post #7 of 30 Old 06-20-2012, 10:48 AM
scubamc
Originally Posted by 1988jeepyj View Post
That is cool...
But not worth $2500 IMO.
scubamc is offline
post #8 of 30 Old 06-20-2012, 10:51 AM
1988jeepyj
Ouch, and it's "starting " at $2500 not including mounts or options. Really gotta love your yj to upgrade this route
1988 YJ 2.5, again!
post #9 of 30 Old 06-20-2012, 12:02 PM
crackedcornish
still, it's cheaper than buying that 4 door Unlimited, and gives the OP a chance to keep the YJ that he has owned 20 years and loves
and as far as the motor mounts go, I would look at it as an opportunity to put that small block in...hmmm, anyone else want a Hemi-powered, coil sprung YJ
post #10 of 30 Old 06-21-2012, 01:54 PM Thread Starter
rage4order
2015 JK Wrangler
Well, to start off, my springs are Black Diamond brand that came with my 3.5" lift kit. I have been tempted to start off on the low end(price-wise) and work from there- maybe replace the shocks, then the leafs. One of the main reasons I like my YJ is 1)it's paid for, 2)parts are relatively cheap and easy to find, and 3)if I damage anything it won't hurt as much as damaging a new Unlimited!
I hadn't really thought(or didn't even KNOW) about swapping out my frame. That's a bit beyond my mechanical abilities and patience. I was hoping I could find a fairly simple suspension solution that could possibly smooth out my ride. Are those Black Diamond leafs considered stiff? I will say, my Jeep did seem to get bouncier after I put on the lift kit...but then again, I was replacing 15 year old leafs with 180K miles on 'em!
post #11 of 30 Old 06-21-2012, 02:42 PM
YJ4LIFE
Maybe buy a flopped over tj and put ur body on it
'89 YJ, 4.2L, ax-15, B&M shifter, 1" BL, TJ flares, '99 intake, '91 EFI, 5.0L explorer injectors, GenRight tank & stretch, 35" ProComp Xtreme muds, 52" chevy springs rear, 44044 Ranchos front.....
YJ4LIFE is offline
post #12 of 30 Old 06-21-2012, 02:51 PM
Anticanman
RIP one good jeeper
Anticanman's Avatar
I honestly think that replacing the springs and shocks with a little higher quality parts is the best way to go. I wouldn't recommend a coil conversion to anyone running the stock front axle or tires under 35". If you want better ride quality and not insane articulation, then call BDS and get a new set of leaf springs comparable in size to what you have. Shocks are a touchy subject but I love my BDS valved Fox shocks. Whether it be highway driving, racing through forest roads or rock crawling, BDS is unparalleled as a multipurpose daily driving/weekend wheeling spring.
Luck Favours The Prepared
Anticanman is offline
post #13 of 30 Old 06-21-2012, 03:01 PM Thread Starter
rage4order
2015 JK Wrangler
What brand leafs and shocks would you guys recommend? I imagine some brands are stiffer than others. Is Black Diamond considered a "low-end" brand?
post #14 of 30 Old 06-21-2012, 03:15 PM
crackedcornish
if I were looking for a softer ride (and I'm not..since my fabtech 3 1/2" springs/shocks ride pretty smoothly to me, and I'm in my 50's), I would have to give some serious consideration to OME 36R's or BDS 2 1/2" springs, some nice soft shocks (perhaps Bilsteins 5150's) and a 1" body lift, rather than taking a chance on another brand of 3 1/2" springs, since ride quality and comfort is a pretty subjective thing.
and remember, you could install a coil spring conversion, and end up with a ride as stiff or stiffer than you have now
post #15 of 30 Old 06-21-2012, 03:37 PM Thread Starter
rage4order
2015 JK Wrangler
I wonder if part of the problem is I don't know if I need a softer ride or a stiffer ride! My jeep just seems very bouncy. I mean, I drive over the small seams where bridges meet the road and I bounce around a couple of times before it settles back down.
That is exactly what I'm afraid of.
EXPLORER STAGE 2 LEAF-TO-COIL SUSPENSION CONVERSION WITH 6" LIFT by ProComp MarylandJeep91 YJ Wrangler Technical Forum 9 03-01-2010 05:50 PM
coil suspension conversion ati2de22 YJ Wrangler Technical Forum 13 11-12-2008 08:48 PM
Pro Comp 5" Coil Spring Conversion (CSC)Suspension System ESAUCEDA YJ Wrangler Technical Forum 2 03-29-2008 06:47 AM
Coil Spring Conversion Suspension for YJ atek YJ Wrangler Technical Forum 1 09-02-2007 08:30 AM
Coil Conversion? BzJeep YJ Wrangler Technical Forum 1 03-05-2002 09:47 PM
