Coil over on a yj - JeepForum.com
post #1 of 30 Old 08-30-2007, 10:08 AM Thread Starter
dell25computer
Coil over on a yj
I am thinking about doing a coil over suspensio on a wrangler yj does anybody have any thoughts or suggestions on this matter. I plan on making alot of parts myself just having to buy the coils and shocks. Is there other things that i may need to be concerned about. The more informaton the better.
dell25computer is offline
post #2 of 30 Old 08-30-2007, 10:44 AM
Punisher
Coil overs....or just coils?
Coils would be easier unless you're going fullwidths.
FRONT:
XJ HPD30 with some RE 3.5" coils, Blue Torch Fab Coil buckets for the frame side. Custom trac-bar w/johnny joint and a poly bushing on the other end. RE XJ Super-Flex control arms (or a custom Y-link setup similar to TNT's XJ long-arm kit)
REAR:
Poly-Performance 4 link kit with some RE 5.5" springs and BTF coil buckets.
Its not going to be easy on stock width axles either way, and you'll probably have more into the suspension than the Jeep when all is said and done
(gotta factor in built axles and bigger tires too...)
Things you'll need to consider (if you're haven't done them already)
  • Extended Brake lines
  • Longer shocks and shock towers
  • SYE and CV driveshaft are going to be MUST HAVE items if you are going big enough to warrant coil-overs (or even a coil swap)
Punisher is offline
post #3 of 30 Old 08-30-2007, 12:57 PM
Tulsachokehold
It will not be cheap to do a 4link suspension on a YJ. You better do all kinds of research on it before you start it. When you think you know wheat you are doing, research more. If you are going to 4 link your rig, you might as well upgrade the axles with you are there. D60 rear and D44 front minimum. don't half *** it!
Edit... also, that online 4 link calculator is pretty much worthless unless you are building a tube buggy from the ground up.
Tulsachokehold is offline
post #4 of 30 Old 08-30-2007, 05:29 PM
Hackle
Hackle's Avatar
It will never work
BTW I have full width axles and without them this would be very hard to do as you just run out of room.
89 YJ Nearly Stock:)
3 link w/ coilovers front. 4 link coil over rear, 39.5" IROC's, Walker Evans Beadlocks, Rear 60 w/spool, Tera Low, Front 60 w/ OX Locker, Warn 9000, & a few others. New 4.0 HO
Hackle is offline
post #5 of 30 Old 08-30-2007, 05:51 PM
Joe Dillard
Electric Chair Operator
Joe Dillard's Avatar
nailer341 is in the middle of doing a coilover on his YJ. I got a glimps of it last week. It's a work of art fitment-wise with an HPD30, but he's almost there & no doubt alot of fab work is involved.
Perhaps he'll post a few pics that'd help if you're looking at keeping the D30.
Joe Dillard is offline
post #6 of 30 Old 08-30-2007, 07:22 PM
zman
Yep, don't think it can be done.
1995 YJ on 40's * 2002 TJ on 37's * 2003 TJ on 33's * 2011 WK Larado X w Hemi
zman is offline
post #7 of 30 Old 08-30-2007, 07:33 PM
91yjwrangler6
i wouldn't even want to attempt doing coilovers on stock widt axles. it gets tight in the rear with just SOA and a ladder bar
91 yj, 4.0, AX15, SOA, 8.8 rear, 4.88 gears, 2.5 inch springs front, m.o.r.e shackle reversal, m.o.r.e shock hoops, 3 inch springs in rear, bilstein 5150's, shock bar, m.o.r.e traction bar, lockers, m.o.r.e high steer, SYE, old school bronco cv shaft, tube fenders, 36 inch tsl's
91yjwrangler6 is offline
post #8 of 30 Old 08-31-2007, 05:00 AM Thread Starter
dell25computer
coils
What is the difference between just coils and coil over
post #9 of 30 Old 08-31-2007, 05:48 AM
Tulsachokehold
Coil suspension:
See the coild are what hold the rig up. the shocks just work as typical shocks..
This is a coilover suspension:
See the coil and the shock are one in the same and that is what hold your rig up. and a typical coilover cost about $500 each.
But you could also do a similar set up to the coilover and use Airshocks. they will runn $250-300 each depending on brand, size and who you buy them from.
This rig is running airshocks:
now do you want to get into a quarter elliptical suspension?
post #10 of 30 Old 08-31-2007, 06:03 AM Thread Starter
dell25computer
coil over
Can I do this setup with the stock axles
post #11 of 30 Old 08-31-2007, 06:23 AM
rustywrangler
Got my eye on you.....
rustywrangler's Avatar
I guess my question is: Why do you want to do it?? Is there a reason that pushed you in this direction???
Congenital Heart Disease is a reality for me, BOTH of my children have it. Please read up and become aware for future generations
Lydia Ann-Acquired 08/05/05 Open Heart surgery 08/10/05
Jacob Patrick-Acquired 01/17/08 Open Heart surgery 02/15/08
rustywrangler is offline
post #12 of 30 Old 08-31-2007, 06:35 AM
Tulsachokehold
You can do it, if you realy want it. but with stock axles, is it realy worth it?
post #13 of 30 Old 08-31-2007, 06:46 AM Thread Starter
dell25computer
coil over
The reason that i want to do the coil spring suspension is because I put a 3.5" lift on and the ride is just so bouncy and rough that i can not stand it. I have taken it out in the woods but i think if i did a coil spring lift that it would be alot nicer ride and that s what i am going for. I want to be able to have a nice ride but also be able to take the jeep in the woods and feel safe as well.
post #14 of 30 Old 08-31-2007, 07:23 AM
mean90yj
Yota Recovery Specialist
mean90yj's Avatar
if you want to feel safe you can always just beef up the stock roll cage....or buy a helmet
'90 I6 258 w/ Weber 32-36 Carb.
32" BF M/T's with cragar rims
5" BDS springs, MORE greasable shackles, XJ driveshaft, AA SYE kit, RE SS brake lines. Bilstein 5150's, 255/70 valving all around, 14" travel in front, 10" in rear.
~Enjoy>>>
JF MOTO>>>>"Ban a tard...save a life" <<<contributed by leftlanetruckin
OMNIPOTENCE...gotta get me some of that
mean90yj is offline
post #15 of 30 Old 08-31-2007, 07:38 AM Thread Starter
dell25computer
coil over
Yeah i realize there are different options but it is not even enjoyable to drive on certain roads and the roads that i have to come to work are not enjoyable so therfor i am thinking of different ways that i can make it more enjoyable and the coil spring is the way that seems to me the best way to get that result
What size Coil spacer should I get? 3/4" or 1 3/4" with new coil springs? ieatchickens TJ Wrangler Technical Forum 5 01-24-2011 11:24 AM
SE coil vs Rubi coil for sagging rear NYTJ TJ Wrangler Technical Forum 6 04-15-2008 07:52 AM
OME install A coil / B coil rehot TJ Wrangler Technical Forum 7 10-30-2006 11:45 AM
Coil springs or coil spacers? SecondTJ TJ Wrangler Technical Forum 34 10-18-2006 03:33 AM
Coil thecarman YJ Wrangler Technical Forum 4 08-11-2003 06:14 PM
