Coil over conversion - JeepForum.com
post #1 of 18 Old 10-15-2010, 03:08 PM Thread Starter
digizure
Should I get a TJ front axle and then do a coil-over conversion on my YJ?
Is there a step by step write up on the conversion? I also heard it is better to do a coil conversion for the front and keep the leaf springs for the rear. If this is true, why?
FYI, I usually off-road on rocks, no mud, and I wanted to make sure that the conversion is the best way to go.
Thanks.
digizure is offline
post #2 of 18 Old 10-15-2010, 04:52 PM
crusty1007
it depends on who you talk to.
Some will tell you leafs in the front & link it in the rear.
Some might tell you the other way.
Personally I did a 3 link front with Fox 2.0 C/O's & spring under in the rear.
I used our basic 3 link kit.
Here's one of the used to be local guys 3 link on his YJ with a D60:
Here's progress photo's of YJ we did a while back:
LINK
Click the sig for everything you need to build a JEEP... 805-706-0232
NEW PRODUCTS ADDED DAILY !!!
----> Click and download the new catalog!!!
crusty1007 is offline
post #3 of 18 Old 10-16-2010, 09:27 PM Thread Starter
digizure
Jeez, I found a coil over conversion kit for $4399.99. There's no way I will pay that much! Does anyone here know of a cheaper kit? Or am I better off going with SOA? Which is better and why, SOA or coil over conversion?
M
digizure is offline
post #4 of 18 Old 10-16-2010, 09:39 PM
4.7stroker
I firmly believe the best way to get a coil over Jeep is to sell your rig and buy a TJ.
The cost of a conversion is often much more than the YJ is worth.
Dwayne
[url]
Prevent Flat Tappet Cam Failure.
[url]
4.7stroker is offline
post #5 of 18 Old 10-16-2010, 09:47 PM Thread Starter
digizure
Yeah, that's what it looks like now. I think I'd save a lot of money if I just sell my YJ and get a TJ. What a bummer. I really love my YJ.
digizure is offline
post #6 of 18 Old 10-17-2010, 09:53 PM
E_ROCK
I don't get it. Any coilover kit is going to require you to pretty much replace almost everything stock suspension wise. So, buying a TJ is not going to net you any gain over a YJ to do a full blown coilover/linked suspension.
Any good coilover kit or fabbed suspension is going to consist of upgraded shock mount/tower, axle trusses, heavy duty C/A brackets on both the axle and frame side, quality C/A with beefy joints, graded hardware, and oh those blingy shocks.
That doesn't even touch the other stuff you either have to address or think about changing like exhaust modifications, gas tank/fuel cell, bump stop options, steering problems, C/A integrated into skid plates, etc.
If you feel like going that route, but don't have the cash. Just do one end, front or rear, like previously suggested.
Garage Monkey, Wheeling Junkie
E_ROCK is offline
post #7 of 18 Old 10-17-2010, 10:09 PM
sebastian22
here is some good info for you...
http://www.jeepforum.com/forum/f12/m...ersion-565241/
http://www.jeepforum.com/forum/f12/k...ersion-978002/
if you can fab or have a buddy who can, then you would be in good shape....if you have to pay actual shop fees to do it, you will pay too much.
95 Black YJ
sebastian22 is offline
post #8 of 18 Old 10-18-2010, 01:50 PM
E_ROCK
The OP asked about coilovers, not a coil conversion.
E_ROCK is offline
post #9 of 18 Old 10-18-2010, 02:42 PM
ZeroGravity
M
The first person that responded sells the 3-link kit in the photos for $1150.
Poly Performance JEEP/TRUCK & BUGGY*::*Suspension Kits & Parts*::*Universal Suspension Systems*::*Poly Performance Universal 3-Link Weld-On Front Kit - 4X4 Off-Road, JK Synergy Suspension Systems, Fox Racing Shox, Beard, CNC Brakes, Johnny Joints®, C
If I was going to use a D30 for a springover conversion, I would just modify my current axle. Besides the disconnect issue, I don't see what advantage purchasing a TJ axle offers you besides maybe not having to weld on new perches, which you may have to regardless of the axle.
You can use solid front axle shafts out of non-disconnect XJs and TJs in your D30.
What are the rest of the plans for your build?
91 YJ
98 XJ
2 door love
The U.S. Army vaguely envisioned something bigger than a motorcycle, smaller than a truck, and undaunted by the most difficult terrain.
ZeroGravity is offline
post #10 of 18 Old 10-18-2010, 04:37 PM Thread Starter
digizure
Okay, lemme clarify...
the reason why I want the coilover conversion is because I'd get better flex and control when off-roading. I also heard that my Jeep would run smoother on-road since my Jeep is also a DD. The other option I have is SOA but I am not sure what are the pro's and con's when I match up SOA and coilover conversion? Anyone?
The "rest of my plan" is to install SYE and CV shaft. That's pretty much it for now... maybe a rear locker in the future... am still debating on which locker I should go with. I prefer something that is selectable.
M
digizure is offline
post #11 of 18 Old 10-19-2010, 09:54 AM
sebastian22
i know you probably dont want to hear this, but for a daily driver, its best to just get a good spring under lift kit and leave it be. a YJ properly set up with a SUA lift can get through a lot and still be good as a DD.
SYE and CV shaft are a good idea...and for a DD a selectable locker is preferred.
95 Black YJ
post #12 of 18 Old 10-19-2010, 11:24 AM
fratis
fratis's Avatar
doing a coil-over conversion at home is a large involved project. i would never purposely dissuade anyone from doing so, however, i would just analyze your home situation very carefully before embarking on this project. mid thirties can be when life gets real serious for a lot of us. i for one have put off a number of jeep projects and career advancement simply so i dont miss the kids growing up. ill have plenty of time to tinker when the kids are older and think they know it all anyways.
polyperformance is the place to start the hardware research. stick with the yj if you want a full blown coil-over. much simpler to work with.
if coils are good enough, there was a guy on here who did an absolutely excellent yj to tj suspension conversion.
-gotta get the kids off to school now.....
fratis is offline
post #13 of 18 Old 10-19-2010, 03:13 PM Thread Starter
digizure
I appreciate y'all's honesty. I have no kids... yet.
Or maybe it is cheaper to go with coil spring conversion and replace the shocks whenever necessary?
M
digizure is offline
post #14 of 18 Old 10-08-2013, 05:21 PM
Bravo1782
Hey, just going to weigh in on a couple of thoughts, for what it's worth...
1. Don't underestimate the power of leaf springs. They're tough and can flex pretty well. Are they going to outflex someone with a long arm suspension kit? Of course not. But it depends on what you're doing. Are you a weekend warrior that like to wheel his jeep from time to time, but mostly rocks it as a DD (which it sounds like you are)? I wouldn't mess with this whole mess than...I'd get a nice life kit, do it right (with a SYE and a nice driveshaft) and put money elsewhere.
2. SYE...dude...get one. You'll be glad you did in the long run
3. If you're rocking a d35 (like me ) I would be FAR more worried about replacing that than I would be about doing a major system-wide suspension overhaul. I'd do an 8.8\d44 swap in the rear, re-gear, selectable locker (I'm going Ox, do whatever makes you feel good) and toughen up that front d30 (even if you're just going to swap in the solid passanger side axle shaft. If you want to get real serious, you can put chomo axle shafts and a locker in the d30, it's really up to you.
Just some thoughts, good luck!
Bravo1782 is offline
post #15 of 18 Old 10-08-2013, 05:52 PM
Joe Dillard
Electric Chair Operator
Joe Dillard's Avatar
Not to damper your input, but the OP lives here in San Diego (as of ~3 years ago) and has done an SOA conversion, rear axle swap, SYE, gears, hysteer, lockers, shock relocations, blah blah blah.
Joe Dillard is offline
coil over conversion revrider9 YJ Wrangler Technical Forum 21 11-01-2007 07:05 AM
Coil conversion gwfoos YJ Wrangler Technical Forum 3 04-26-2006 03:43 PM
YJ Coil Conversion??? markburtenshaw YJ Wrangler Technical Forum 22 06-08-2004 08:02 AM
Coil Conversion Sidewalkman YJ Wrangler Technical Forum 3 07-10-2003 05:32 PM
coil conversion Meister_jeep YJ Wrangler Technical Forum 4 10-06-2002 04:19 PM
