coil over axle conversion - JeepForum.com
post #1 of 6 Old 05-06-2010, 07:42 PM Thread Starter
erik71clark
how do i flip my axles under my leaf spring. and what all do i have to do?
erik71clark is offline
post #2 of 6 Old 05-06-2010, 07:47 PM
LuckRider
LuckRider's Avatar
If you want coil overs, you will need to build a full new suspension with upper and lower control arms and all of the other things that go along with a coil setup. It sounds like you have a lot of research to do.
Support Our Troops!
JFI Member #7:
BESRK Rear Bumper, Hella 500s
LuckRider is offline
post #3 of 6 Old 05-06-2010, 07:48 PM
TSEJEEPERS
This is not a coil over axle conversion.
It is a Spring over axle conversion. Do a search for SOA. Also look in the frequently asked questions.
93 YJ SOA 2" springs front, XJ springs rear w/main leaf added, High pinon 9 inch rear detroit locker front Dana 44 ARB 4.56 Gears, 36 inch Irok tires too much to list.
TSEJEEPERS is offline
post #4 of 6 Old 05-06-2010, 07:55 PM
LuckRider
LuckRider's Avatar
That is what I figured he really wanted. I figured if I posted what goes along with a coil over conversion, he would realize it is very different from what he is trying to do.
Support Our Troops!
JFI Member #7:
post #5 of 6 Old 05-06-2010, 09:02 PM
Joe Dillard
Electric Chair Operator
Joe Dillard's Avatar
Regretfully, you seem to be terribly confused, possibly misinformed, and you should read the Frequently Asked Questions (FAQ) sticky thread (all of it including its links, probably more than once).
Till then, you are spinning your wheels and waisting your time.
Joe Dillard is offline
post #6 of 6 Old 05-06-2010, 09:15 PM
notmyj
What do you need to do? Save up $1000-$1500 depending on your jeep and abilities, not including wheels and tires or lockers and regearing the axles. Read as many SOA build threads and web sites as you can find. Write a list of parts needed for your build and stick to it, pay close attn to axles and steering. Learn to weld, buy a welder, and be mechanically inclined.
A lot more to an SOA than just flipping the axle to the bottom of the springs. Axle upgrades, re gearing the diffs, steering, fab parts, drive line issues, etc. Its simple at first, untill you go to do it, then it can easily turn into pandoras box if your not prepared for what has to be done. The devil is in the details. Do your research and do it right the first time. SOA is not cheap, easy nor fast.
If it has tracks, tires or tits, its gonna cause a problem.
"Everytime someone "upgrades" a D35, an angel looses its wings."
"Dizzy" - What SnoopDog would call a Distributor if he was a mechanic. I cringe every time I hear this moronic term
Originally Posted by Warren Zevon
Send lawyers, guns and money. The **** has hit the fan...
92, 4.0, AW4, 8.8, D30, 15x10, 37's, SOA etc, etc
92, 2.5, 30, 8.8, 4.88, Locked, Winch, 15x8, 35's, 3.5" (RIP)
notmyj is offline
yj suspension
My YJ Coil Conversion CrazyCooter YJ Wrangler Technical Forum 71 11-20-2011 05:31 PM
Coil Conversion Douglas S. YJ Wrangler Technical Forum 27 04-03-2011 01:10 PM
Coil over conversion Kris_Kris TJ Wrangler Technical Forum 24 01-22-2010 08:19 PM
Coil Conversion BORRONGO YJ Wrangler Technical Forum 24 10-25-2004 07:56 AM
coil conversion kit arnoo YJ Wrangler Technical Forum 2 08-25-2003 09:45 PM
