coil getting constant voltage instead of pulsating - JeepForum.com
post #1 of 6 Old 07-12-2010, 04:52 PM Thread Starter
headstrong50
i recently put my drive train back into my 93 yj after getting everything rebuilt. the jeep fired fine before, but when we went to turn it over, it wouldnt. i bought a new coil because i wasnt getting any spark, but that didnt help anything, so i tested the volts and instead of it pulsating at 12 volts, it was constant. what does this mean? or am i way off?
going off road is like being married, its great until you bang something you shouldnt.
headstrong50 is offline
post #2 of 6 Old 07-12-2010, 05:16 PM
laybackman
Bikini Bridge Inspector
laybackman's Avatar
2010 JK Wrangler
Was this a complete disassembly/rebuild of the engine?
"turn it over" does that mean the starter turns the engine but it does not fire?
Do you have fuel pressure at the fuel rail? Do you have gas? I ask becasue I have done a bunch of rebuilds and I am quite meticulous YET one time I spent an entire 12 hour day chasing a problem....yep no fuel!
If you have no fuel pressure at the fuel rail or high voltage or any spark at all coming out if the distributer you may have a problem with the ECM. Does your CEL come on when you turn the ignition switch to the ON position?
If not then you have an ECM problem.
IF the CEL does go on and you have fuel opressure at the rail but it will not fire up I would suspect the crank sensor first.
The coil input is always 12v when starting/running. It is the output voltage to the distibuter cap that is important. That voltage depends on the coil output. But if the crank sensor or the vss sensor 'sees' no movement of the turning asssembly you get no spark of fuel after a second or so of cranking.
EDIT if the sensor in the distributer sees no mevement the same thing happens I beleive.
Do you know what was good about the good old days? I wasn't good, And I wasn't old!
Senators and Congressman should wear uniforms like NASCAR drivers so we could identify their corporate sponsors....
laybackman is offline
post #3 of 6 Old 07-12-2010, 08:19 PM
ctm
for the coil it is the ground connection that is pulsed by the ignition module on the trigger signal from the distributor
ctm is offline
post #4 of 6 Old 07-13-2010, 12:15 AM Thread Starter
headstrong50
the engine cranks, just does not run. i checked the fuel rail and i have pressure.
post #5 of 6 Old 07-13-2010, 01:51 AM
Douglas S.
Have you checked for codes?
1991 Land Cruiser HDJ81
Douglas S. is offline
post #6 of 6 Old 07-13-2010, 03:32 AM
Mark05059
sounding like a crank sensor issue.
1998 ZJ 5.2 Auto
1989 Wrangler Black Bone Stock 2.5l 5spd
/l , [____],
|---L--[]lllllll[]-
()_) ()_)==O=)_)
Mark05059 is offline
Pulsating Brakes turkish6 TJ Wrangler Technical Forum 8 04-01-2010 08:35 PM
No Spark but coil has voltage at supply bsousa YJ Wrangler Technical Forum 2 06-12-2008 04:51 PM
Voltage to the coil ? CUtigger YJ Wrangler Technical Forum 19 05-30-2008 07:17 AM
90YJ No Voltage at Coil ctm YJ Wrangler Technical Forum 7 02-09-2008 02:43 PM
coil voltage Scurv YJ Wrangler Technical Forum 1 03-10-2007 09:22 PM
