Code Readers? - JeepForum.com
post #1 of 2 Old 07-30-2002, 07:06 PM Thread Starter
Shifty
Code Readers?
92 YJ 4.0L, I am still tracking down my sputtering problem, at all RPM's but seems to go away when in 4th or 5th on the highway, even at 2k Rpms at high speed it is fine. however in stop and go traffic it appears when in 3rd at 2k 30mph or so it sputters more often. Can heat buildup have something to do with throwing off the sensor on the mass air flow sensor?
Ultimately in regards to the code readers, if I am not getting any engine dash lights or errors via the key\off trick to read the computer will a code reader really tell me much more?
THanks!
Shifty is offline
post #2 of 2 Old 07-31-2002, 04:58 AM
jeeptuff
I would say if you were closer to the Seattle area I would have you swing by my place and i would hook up the Snap-On scan tool up to her...
Eric
Once again Jeepless in Seattle
jeeptuff is offline
Misfire code P0301 & Fuel level code P0463 related? -OlllllO- TJ Wrangler Technical Forum 6 04-28-2010 03:55 PM
YJ EVAP solenoid code/AC Code, Stalling/Dying when coming to a stop issues fyallm YJ Wrangler Technical Forum 16 07-13-2009 08:33 AM
Scanners v.s. Readers Tim TJ Wrangler Technical Forum 4 10-04-2008 08:53 AM
Code Readers for 1995 and below Jeeps? 95GreenWrangler YJ Wrangler Technical Forum 14 07-30-2008 10:19 PM
code readers ruckapitjeep TJ Wrangler Technical Forum 4 03-06-2005 01:37 PM
