Code 47 any electrical guru's out there - JeepForum.com
post #1 of 12 Old 07-01-2013, 09:01 AM Thread Starter
Siva283
I will be testing this tonight with a new alternater from the 98 durango currently parked next to it but I am at work right now and this is really bothering me. As some of you may remember Que and Pete for instance. I had an electrical short a few months ago. Thought it was all straight. SO I finally give the dirty girl a bath yesterday and I guess it made her mad. I take it for a drive after cleaning the 3 tons of mud off and 15 minutes into the ride the check engine light comes on. I look over and my alt is not charging at all. Nothing Nadda Zip Zilch. Doesnt matter if I rev the engine up absolutly no change. I am getting code 47 Battery undervoltage. Now again as a few know I have a huge battery 1250 CCA at 32 degrees. I cant still start the jeep run lights and everything off the battery so I know its not the battery. At first after I fixed the electrical issue it seemed to charge about 1.5 volts high going by the gauge but a multimeter read 14.8. Lately it has been charging at 14 - 14.2. I dont know why but I have this feeling it may be the notorius ECM issue. Hopefully I am wrong. Does anyone know the way to troubleshoot the ECM side of it. Obviously I will replace the alt since I have a perfectly good free one I can use temporarily since noone seems to want to buy the awesome 5.9 durango I have. But if I find this doesnt fix the issue what is the best way to test the ECM control circut. Do I just hook a multimeter up to the field wires and look for voltage. Would it really be that simple. I already miss being able to call Que up and ask him it made life much easier.
Hopefully he will be back in a few weeks.
Ask me how I know...
Siva283 is offline
post #2 of 12 Old 07-01-2013, 11:28 AM
tdewit
tdewit is offline
post #3 of 12 Old 07-01-2013, 11:44 AM Thread Starter
Siva283
That link does me no good. It does not answer my question. I am trying to find proper test procedures for the ECM circut. I am also not getting 41 which is the field coil. I am only getting 47 which is battery under voltage. My battery however is fine. I have discovered this through my not so scientific test. The Alt is putting out 0 voltage. That tells me my field coil is completly toasted or I have an ecm issue. I am trying to find out the proper way to test the ECM charge circut.
Siva283 is offline
post #4 of 12 Old 07-01-2013, 01:34 PM
VenomousMaximus
The PCM puts power on the Dg/Vlt wire to the Alternator field wire from pin C25 while the engine is running and then grounds the Dg / wire at pin B10 of the PCM to turn the field on & off to maintain desired charge state.
VenomousMaximus is offline
post #5 of 12 Old 07-01-2013, 01:41 PM
VenomousMaximus
Also try a wiggle test at the connectors watching for changes & make sure all the pins in the connector are clean & not corroded or lose.. make sure to always use dielectric grease at all connections.
post #6 of 12 Old 07-01-2013, 02:43 PM Thread Starter
Siva283
Que taught me well Dielectric grease on everything. I checked connectors and tried the wiggle test with no change. Should I test field voltage at the PCM or at the connector on the alt? I am assuming I should ground the meter to battery when I do this test and only use the positive probe on the pins or at the connector? Thanks for the input that was the type of info I was looking for
Siva283 is offline
post #7 of 12 Old 07-01-2013, 06:19 PM
pete1991YJ
You could do it by process of elimination. First I would measure how many ohms does the field coil have, with the als completely disconnected and everything off. If the reading is zero or infinite, then you know the field coil is shot but the ECU circuit maybe still good. The ECU circuit should be putting out a certain DC voltage IIRC it was less than 12 volts but I don't recall the exact number.
In a pinch (emergency) you can always feed a field coil directly from the batt positive thru a brakelight bulb - the bulb will limit current to a safe amount usually around 5 Amps.
Yeah, I know ytou wish it was Que
***--- Wrecking Crew member ---***
"I've prolly been around longer than you think"
pete1991YJ is offline
post #8 of 12 Old 07-01-2013, 06:25 PM
pete1991YJ
BTW you can stick a 4-ohm 20-watt resistor (or similar heavy-duty) across the field wirew without conmnecting them to the alt, this will fake the computer into thinking the alt is there! You could try this and see if the error code goes away, or use it for further testing purposes. Less than 5 bux at radio shack.
post #9 of 12 Old 07-01-2013, 07:21 PM Thread Starter
Siva283
Lol you know your loved too pete. I was worried I haven't seen you in awhile. I tested my fueld circut earlier. The ecm slowly climbed from 5 volts to 10. I am guessing it was increasing voltage to the field trying to get the alt to charge. The alt is putting out zero still though. I only read battery voltage everywhere I tested. The battery is good though I just stuck it in the durango and it fired it up and pulled 14 while the durango was running. If the people coming to see it tomorrow don't buy it I am stealing its alt. and throwing it in the jeep to see what happens. Since its a 98 and all. Its the 5.9 so if it doesn't sell soon I sense a neq motor for the jeep in the 5.9 flavor
Sent from my SPH-L300 using JeepForum
Siva283 is offline
post #10 of 12 Old 07-01-2013, 07:28 PM
pete1991YJ
If the alt was still putting zero even with field voltage then there's definitely6 a prob. Just for giggles, try checking the output with the volts set for "AC". Its one way to check for a bad diode. I've been in school for CNC machine shop and programming so its been kinda hairy lately... the only time I have is very early in the AM.
post #11 of 12 Old 07-01-2013, 07:31 PM Thread Starter
Siva283
Hmmm I will give that a shot tomorrow its time for a shower and a few shots to sleep well. Been a bad day. Luckily the jeep is not my only vehicle anymore so I don't have to be so rushed. As always pete its great to hear from you and nice to see you around. I really was wondering if something happened as you are missed when your not here as well.
Siva283 is offline
post #12 of 12 Old 07-04-2013, 01:47 PM Thread Starter
Siva283
It was the field coil new alt and new battery and its charging perfect. My battery also had an internal short that reared its head when it got warm.
Siva283 is offline
