code 27 - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > YJ Wrangler Technical Forum > code 27
SPARTAN LOCKERS are on sale BIG TIME at ROCKRIDGE 4WD!TJ Wrangler 4" Rough Country Suspension Lift Kits in Engo winches available at www.rockridge4wd.com! Free shipp
Unread 09-24-2014, 05:45 PM   #1
Johnnyxl
code 27
i usually try and fix by reading however this one is beyond me. i have a code 27 all 6 injectors firing. fuel pump relay has acted up twice after about a 20 min drive i swapped my a/c relay. back on the road 20 min later same thing put old one back in, back on the road. any help would be great.
Johnnyxl is offline   Reply With Quote Quick reply to this message
Unread 09-24-2014, 07:46 PM   #2
sprngrider
27 is usually caused by a loose injector plug or corrosion inside the plug.
1994 2.5L WRANGLER S.
sprngrider is offline   Reply With Quote Quick reply to this message
Unread 09-24-2014, 08:17 PM   #3
Johnnyxl
all 6 injectors are firing i am leaning to the cause being related to what is causing the relays to go out/overheat.
Unread 09-24-2014, 08:19 PM   #4
Johnnyxl
the jeep is running fine at the moment, but something caused those relays to go.
Unread 09-27-2014, 02:13 PM   #5
Johnnyxl
i inspected ALL the wires in the engine bay and underneath and found nothing. i removed the fuel pump relay and cleaned all the slots and closed the gaps. i then drove the jeep for 1hr and 20 min with no problems. i did notice that the fuel pump relay is hot to touch. it won't take the skin off but its hot. is that normal?
Unread 10-20-2014, 10:59 AM   #6
SurferJ
Having this code too. I replaced my gas tank last week but used the same pump and sending unit. All wires are good inside and outside the tank. I swapped in a new fuel pump relay and fuse as well. I guess I'll check injector wires but I didn't touch those. Figuring it's gotta be something I did during the swap
SurferJ is offline   Reply With Quote Quick reply to this message
Unread 10-20-2014, 02:14 PM   #7
Que89YJ
Try pull the battery cable to clear the codes and see if it comes back.
Que89YJ is offline   Reply With Quote Quick reply to this message
Unread 10-21-2014, 07:57 PM   #8
Johnnyxl
I have driven the yj a few times since my last post. I changed the battery to an optima (starts faster) and the fuel filter (gas flowed through pretty fast). The relay doesn't get as hot. But the code 27 appears on start up but goes away after about 2 min. I do have a turbo but its been on there for about 3 years. All injectors are firing so..................
Unread 10-21-2014, 11:02 PM   #9
Que89YJ
A turbo. Interesting. What set-up are you using? Pics please.
Unread 10-22-2014, 06:43 AM   #10
Que89YJ
Come on, pics and more info! Inquiring minds want to know. I am surprised you are able to run a turbo with OBD 1 and a stock controller.
Unread 10-23-2014, 02:19 PM   #11
Johnnyxl
I tried to upload jpeg file to big. any way the turbo is off a 5 cly volvo. piped in for oil and water cooling. missing link for a v-6 honda accord to handle the map not seeing boost. blue top mustang injectors. 35 tires 4.10 gears. power is not a problem. wide band 02 to verify not running lean. run about 8psi spikes around 10 waste gate with manual boost controller nothing fancy
Unread 10-23-2014, 02:22 PM   #12
Que89YJ
The injector is looking at timing and the injector pulse. Maybe a loose timing chain.
Unread 10-23-2014, 03:22 PM   #13
Johnnyxl
i'm trying
Unread 10-23-2014, 05:26 PM   #14
Que89YJ
That is absolutely awesome. Check for timing chain slack.
Unread 11-01-2014, 11:48 AM   #15
Johnnyxl
code 27
my code 27 ended up being the upstream o2 sensor. all problems now fixed.
