Co2 vs Scuba tank performance? - JeepForum.com
post #1 of 9 Old 03-18-2009, 09:08 PM Thread Starter
ghost183
being an avid boater, i have an abundance of scuba tanks..
these tanks are designed for 3600 psi capabilities, and over an hour of breathing..
i have a 40cf, and an 80..
now...
i was looking at the air manifold, i can just screw in a quick connect and run an air hose for tools and to air up if need be,
anyone have any experiance with this? or direct me to some info?
i googled but it came back with totally irrelevant links... what does the goodyear blimp have to do with running a scuba tank for OBA.. ask google
anyway...
let me know fellas
Important Notice:... DUE TO RECENT BUDGET CUTS, STOCK MARKET PERFORMANCE, RISING COST OF ELECTRICITY, GAS AND OIL... THE LIGHT AT THE END OF THE TUNNEL HAS BEEN TURNED OFF.... WE APOLOGIZE FOR THE INCONVENIENCE............ Regards:... THE GOVERNMENT
ghost183 is offline
post #2 of 9 Old 03-18-2009, 09:15 PM
HotSauceJunky
I have a CO2 tank and I know it pressurized till the contents are liquid. I don't think scuba tanks hold that much pressure. Here is a link that might have some info:
http://www.off-road.com/trucks4x4/ar....jsp?id=263809
HotSauceJunky is offline
post #3 of 9 Old 03-18-2009, 09:34 PM
scubamc
A scuba tank works just fine for running air tools. You would just need to get the proper adapter for the tools. I would suggest finding an older 1st stage regulator to use. You will be running the tools off the low pressure side of the regulator. This pressure will be plenty to run the tools with.
scubamc is offline
post #4 of 9 Old 03-18-2009, 09:37 PM
PILL
CO2, in a tank, never even comes close to 3600PSI. Also, a CO2 tank is filled with liquid CO2 and will have no pressure once there is no more liquid left.
Member 134 of the White Jeep Club
31" BFG A/T's, 130w KC Hilites
PILL is offline
post #5 of 9 Old 03-18-2009, 09:59 PM Thread Starter
ghost183
hmmmm...
that link gave me keywords for more googling..
so ive found out that Co2 compresses to a gas at about 850psi and stored as a liquid... so as the air pressure is depleted, its starts bubbling off liquid to make up to the 850 psi stabilizing point, until air pressure depletes again.. so the 850 psi is the liquids flash point..
wow..
thats amazing.. modern chemistry!!
so thats why the keg tanks in bars lasts for weeks!!!!
apparently, even though the scuba has more pressure, it depletes rather quickly cause youre using its only asset... air.. no liquid is present.., so, air gun, dismount tire, remount, re-inflate all 4 for street use.. = 1/4 pressure left, about 700 psi
but the Co2.. thats another story.. can do the above several times...
anyone have real world info on C02 systems?
im itch'n for OBA, just dont want to remove my A/C or install an electric, i dunk my YJ too often and fear ill fry the electric dunking it..
ghost183 is offline
post #6 of 9 Old 03-31-2009, 08:26 PM
EK91YJ
not to hijack, but are the co2 tanks you are talking about, are they like the ones used for paint ball guns? i would like to be able to fill 4 tires if needed.
Red 5.3L LM7 in progress 4 inch Rubicon Express
EK91YJ is offline
post #7 of 9 Old 03-31-2009, 08:41 PM
Mean Max
Don't poke the bear
Mean Max's Avatar
Nope, bigger.
http://www.stu-offroad.com/recovery/co2/co2-1.htm
Max
Originally Posted by UltimatE View Post
Max has a picture of every Jeep part ever made.
Originally Posted by Benderff View Post
No one here knows what they are talking about. You should try Pirate 4x4 they will be happy to help you.
There is no situation that cannot be improved with a small but well-placed explosive.
Mean Max is offline
post #8 of 9 Old 03-31-2009, 09:55 PM
dadstoy
Not if it matters, but I used a nitrogen tank for a while. I was only able to fill about 9 tires per tank of nitrogen. Nitrogen is filled basically the same way as the scuba tank, by pressure. Like has been said, CO2 is liquid filled. I have aired up around 30 tires per tank of CO2. (man i wish someone else had OBA.........ha)
dadstoy is offline
post #9 of 9 Old 03-31-2009, 10:09 PM Thread Starter
ghost183
lol.. thanks for your input.. but yah, im looking into feasability for an engine driven compressor and if that doesnt pan out, CO2 then..
ghost183 is offline
Why not a SCUBA Tank for tire inflation? medcop JK Wrangler Technical Forum 40 08-01-2013 12:49 AM
Hard start after Scuba Jeepin' YJake YJ Wrangler Technical Forum 6 07-03-2009 09:11 PM
Scuba tank? Gif38 YJ Wrangler Technical Forum 10 07-17-2007 03:07 PM
Scuba tank to fill tires? chris06 TJ Wrangler Technical Forum 10 08-23-2004 10:30 AM
California Tops scuba covers Red97Sport TJ Wrangler Technical Forum 9 07-28-2003 10:34 AM
