Clutch Won't Engage - No Pedal To Speak Of - JeepForum.com
post #1 of 6 Old 01-26-2010, 07:35 PM Thread Starter
tlarwa
Here's the particulars ... '91 YJ, 4.0L. Here's the problem: I have very little (if any) pedal engagement, and cannot shift into gear without "pumping" the clutch pedal a bunch of times (and then it will barely go into gear). Once the clutch engages (or disengages, I guess) I can shift through all the gears. I bled the system, and the clutch cylinder is full. My question is, what needs to be replaced? My guess is that it is a bad clutch master cylinder, but I don't want to start blindly replacing parts. I'm a Miata guy (this is my son's Jeep) and I know about slave cylinder issues on the Miata, having replaced it. Does that go bad as well? Any other ideas? I'm fairly confident it's not the transmission, as it shifts prefectly fine once I can get it to engage. It seems to defintiely be a case of the pedal not being able to engage the clutch to allow me to shift into gear.
I'd appreciate any and all help/advice!
Tom
tlarwa is offline
post #2 of 6 Old 01-26-2010, 07:47 PM
Louie4
"You pass butter"
Louie4's Avatar
Sounds like the clutch master cylinder. Mine had the same issue. I've been through 3 and I finally got a good one. The only other thing it could be is the hydraulic throwout bearing and that involves pulling the tranny.
Lou
YJOTM July 2012
YJOTM February 2014
Louie4 is offline
post #3 of 6 Old 01-26-2010, 07:52 PM
dirtydan69
definitely the clutch master cylinder, this exact thing happened to me. check for leaks on the firewall on both the inside under the dash and in the engine compartment. its either replacing the part or paying someone else to.
dirtydan69 is offline
post #4 of 6 Old 01-26-2010, 07:59 PM Thread Starter
tlarwa
Thanks guys ... just ordered a new one from Rock Auto. Looks to be an easy enough job. Thanks!
tlarwa is offline
post #5 of 6 Old 01-26-2010, 08:12 PM
Mark05059
looks can be VERY deceiving
1998 ZJ 5.2 Auto
1989 Wrangler Black Bone Stock 2.5l 5spd
/l , [____],
|---L--[]lllllll[]-
()_) ()_)==O=)_)
Mark05059 is offline
post #6 of 6 Old 01-26-2010, 09:31 PM
jeepkween
Here's a good write-up if you need it. http://www.jeepforum.com/forum/f12/c...cement-728960/
1990 Jeep YJ: Chevy 350, Auto Trans., Rear Axle ARB Air Locker, 4" Lift, 35"x12.5"-15 BF Goodrich All Terrain T/A tires
Other Jeeps: 1998 Grand Cherokee 5.9 Limited; 2002 Grand Cherokee Overland 4.7L
jeepkween is offline
Clutch Pedal soft, no resistance, does not engage clutch. Shivam YJ Wrangler Technical Forum 22 01-17-2017 12:00 PM
Clutch pedal- low resistance, doesn't engage, but no fluid leaks enfuego TJ Wrangler Technical Forum 20 05-07-2011 09:21 AM
Question about destroying clutch plate WITH CLUTCH PEDAL DEPRESSED JeffB TJ Wrangler Technical Forum 12 07-20-2009 11:29 AM
Clutch will not engage lonestar_yj YJ Wrangler Technical Forum 3 11-26-2008 04:05 PM
Cannot engage clutch... jarods7920 TJ Wrangler Technical Forum 2 11-22-2008 07:32 PM
